Surface Pro 4 Dump fix!
  • xe_d_sono
    • Aug 2013
    • 25
    • Portugal
    I've a Surface Pro 4 after update (bios), blackscreen.
    There is any way to fix this bios?
    I try another dumps, but it's stop on Surface Logo with a unlock red stripe on top the screen (see the atach).
    Thanks.
  • xe_d_sono
    • Aug 2013
    • 25
    • Portugal
    Re: Surface Pro 4 Dump fix!
    Another thing....i cannot access to UEFI menu or boot by the USB drive.
    • xe_d_sono
      • Aug 2013
      • 25
      • Portugal
      I just need a BIOS dump, not all dump.
      If you have a Surface Pro 4 i5 128G you can only dump a Bios Region without open a surface, just run a program.
      • Yehuda170
        • Jan 2015
        • 34
        • Israel
        i have the very same problem with 2 surfaces. the board p/n x911788-009
        i tried a lot of bios dump from different websites, some doesn't gives display. and some gives display,but only stays at surface logo. i tried to clear ME region, changed ME versions. all gives the same results. i think it's not only the bios that got corrupted during the surface firmware update. i think there are more firmwares that got corrupted. i have found an eeprom near the EC chip which is programmable, I have found any dump for it now where.
        i also downloaded the latest FW from microsoft, but struggled to use them to fix mine
        did anyone faced this issue? did someone was able to fix this?
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • FalconPunch
          Surface Pro X 1876 Bios corrupted
          by FalconPunch
          Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
          Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
          08-09-2025, 03:56 AM
        • shadow666
          Surface Book 3 1899_TOP Rev 2.0 Bios Dump
          by shadow666
          hello
          i need surface book 3 dump bios
          Model : 1899
          MB : 1899_TOP
          Rev 2.0
          Serial : 037248401157
          CPU :Core i7-1035G7
          Dump Bios problem is no power
          Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
          Regard...
          02-24-2025, 11:01 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
          by haitham sharabati
          Hello engineers 😀,
          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
          💀 Problem:😅
          - Device shows “Administrator Password”...
          08-07-2025, 04:54 AM
