ASUS X54H (K54L_HDMI R3.0), "Initialise..." and stops
  • inflex
    • Aug 2012
    • 545
    ASUS X54H laptop with K54L_HDMI R3.0 board. Had a bad DC jack, replaced, but now it's showing me the following blue screen before shutting down about 0.5 seconds after.
    If I try without the battery it'll make a note that updating the flash requires a battery with at least 20% charge on the same screen.
    Any ideas? Do I need a new bios?
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • cacla
    • Apr 2015
    • 444
    Re: ASUS X54H (K54L_HDMI R3.0), "Initialise..." and stops
    someone start to flash this unit and never finish
    • inflex
      • Aug 2012
      • 545
      I thought that perhaps myself, except that the client isn't the sort that would ever do that sort of thing (general user). Very strange.
      I'll try get a replacement BIOS and see if that fixes it.
      • cacla
        • Apr 2015
        • 444
        Only reprogram bios
        • inflex
          • Aug 2012
          • 545
          Anyone have the 4MB size BIOS for me to flash to the chip?
          • cacla
            • Apr 2015
            • 444
            Pls sent me sn for you model and i will find in asus system
            • inflex
              • Aug 2012
              • 545
              Have sent you a message, thank you.
              • cacla
                • Apr 2015
                • 444
                try this one but keep old ok and sent msg if is ok or not
                • inflex
                  • Aug 2012
                  • 545
                  Thank you. I've made a copy of the old one, but I worry it is corrupted. I will try this new one.
                  • inflex
                    • Aug 2012
                    • 545
                    Unfortunately the machine now just turns on, no display, no backlight/energize, and the fan runs at 100%
                    There is some USB stick activity for a short time.
                    • cacla
                      • Apr 2015
                      • 444
                      Ok now try this one its my bad sorry pls sent msg
                      • inflex
                        • Aug 2012
                        • 545
                        Many thanks @Cacla - the K54LF1208 works
                        • cacla
                          • Apr 2015
                          • 444
                          You are welcome
                          • inflex
                            • Aug 2012
                            • 545
                            UPDATE:
                            It booted fine, rebooted again okay, I then shut down the system and now it's come back again with the blue-screen as the original-post.
                            Suggestions? Perhaps faulty BIOS chip... or maybe some broken program trying to run on Windows?
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              you should reinstall the OS to see what will happen. If it was not solved, you can do a number of tests.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                I have a membership on bios-downloads and can give you a few more BIOS files to try. If it keeps failing, you have a PCH issue which is killing the BIOS, seen it several times. If the BIOS goes bad again, reflow PCH, this should fix it. If not, you will need to replace the PCH.
                                A working TV? How boring!
                                • inflex
                                  • Aug 2012
                                  • 545
                                  I was just looking at the PCH because I was seeing on the Boardview that a lot of the lines were going right back to it. I'll check them for issues but beyond that if it's the PCH then I'll likely write the system off.
                                  Many thanks for the offer on the BIOS(s).
                                  • inflex
                                    • Aug 2012
                                    • 545
                                    SUMMARY -
                                    Happy to report everything is fixed now, but it wasn't in the end a bad BIOS chip or virus or OS problem.
                                    There was liquid damage in the on/off button of the laptop, causing the machine to glitch off (and the DC Jack was also messed up too) but the kicker was that some liquid must have gotten in to the keyboard and was causing it to start in bios-flash mode
                                    but combined with the rapid turnoff from the messed up on/off button assembly made it look like it was a dead BIOS; and because this would only happen when I had reassembled the machine the first couple of times I started to think that it was something like a CIH virus in the Windows.
                                    So there you have it, a compound issue; DC Jack messed up combined with liquid damage in the on/off switch and keyboard.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      Good job. A lot of times things aren't what they seem to be.
                                      • inflex
                                        • Aug 2012
                                        • 545
                                        And no matter how much you learn, there's always a new curveball to be thrown at you.
                                        On the upside, I worked out how to do bios flashing using a Raspberry Pi rather than dedicated programmer, easier in many ways.
