Need Bios dump for hp spectre 13-h200es
  • eng.umair.a
    • Jun 2016
    • 79
    • Pakistan
    Hi i needbios dump for HP Spectre 13-h200es
    motherboard part number:
    Turning Slate MB
    12315-1
    48.41L11.011
  • eng.umair.a
    • Jun 2016
    • 79
    • Pakistan
    Re: Need Bios dump for hp spectre 13-h200es
    Can anyone help me repair this bios?
    • vhn1998
      • Jun 2015
      • 56
      • Vietnam
      try this
      • angel-boy
        • 550
        or this
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
