Can anyone fix this UX305CA BIOS dump?
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    I think there is a problem with BIOS.
    Please have a look.
    No picture, power and capslock turns on, if I hold power button down it turns off but when I release it- turns back on.
    Asus Zenbook UX305CA
    Best Regards,
    Raitis
  • cacla
    • Apr 2015
    • 444
    Re: Can anyone fix this BIOS dump?
    try this one
    • BremiX
      • Oct 2017
      • 64
      • Latvia
      Originally posted by cacla
      try this one
      Thanks, gonna test it and report results.
      • BremiX
        • Oct 2017
        • 64
        • Latvia
        try this one
        This dump fixed the issue.
        Gonna test it but for now it looks fine.
        Again, thank you!
        • cacla
          • Apr 2015
          • 444
          You are welcome
          • umihotaru
            • Dec 2018
            • japan
            Got exactly same problem. My machine has already 300 one, how can I flash this custom BIOS? Couldn't do that from BIOS setting either WinFlash tool.
              • 22279
              You can flash the bios by starting winflash from a command prompt. Navigate to the installed winflash directory, for example:
              cd C:\Program Files (x86)\ASUS\WinFlash
              Then type and enter:
              Winflash /nodate
              Now you can update or downgrade your bios.
              • jaggi_32
                • Jul 2020
                • 6
                • India
                I have the same problem with my UX305FA. Could this be fixed? Many thanks!
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers 😀,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  💀 Problem:😅
                  - Device shows “Administrator Password”...
                  08-07-2025, 04:54 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
