hp elitebook 840 g4 need password unlock
 Re: hp elitebook 840 g4 need password unlock
 No, not going to happen as you think. There is no software based methods, and if you want to do it - buy a programmer, the cheapest one is ch341a (10 bucks or even cheaper from ali), then read how to use it and we can talk later.----------------------------------------------------------------------------------------------------------------------------------------------------------
 Become a Badcaps supporter
 Thanks to all supporters.​
 ----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
 Got it! Thank you.No, not going to happen as you think. There is no software based methods, and if you want to do it - buy a programmer, the cheapest one is ch341a (10 bucks or even cheaper from ali), then read how to use it and we can talk later.Comment
 I have a password locked (limited lock) cannot update bios... I tried one of the bios submitted in this forum but did not work (motherboard blinking once I put in the bios), here is my password protected bios, can you please unlock it and give me one that works?
 Thanks guysLast edited by SMDFlea; 04-10-2023, 12:39 PM.Comment
 try..Hello,
 Thanks guysLast edited by SMDFlea; 04-10-2023, 12:39 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Every donation made will go towards server fees and maintenance costs.Comment
 Hello thanks for prompt bios sending...
 Same problem, red flashing 5 times (fast) then green bkinks one time (slow blink). Could be some other issue? is it possible that I installed wrongly the chip (I'm sure I installed in the good position as it was before)?
 ThanksLast edited by darkpower; 07-31-2020, 09:43 AM.Comment
 post the original bios not the one you tried on the site.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Steps to flash the bios of elitebook g4 840:
 1- Open the laptop
 2- Remove the battery then the SSD which is very close to the bios chip
 3- protect the surroundings of the bios with aluminium foil or kaptopn tape if you have
 4- remove the wson8 packaged bios chip with a heat gun after putting some flux (if you don't have hot air soldering station you cannot do it!!!)
 5- connect it to ch341a programmer using twizzers or by soldering it
 6- make 2-3 copies of the locked bios and verify each time that the buffer & content of the chip are exactly the same (very important)
 7- post the bios on the forum
 8- download the unlocked bios
 9- Erase the eeprom and write the unlocked bios
 10- Solder the bios back on the laptop after applying flux, put more tin on the contacts and remove tin from the central one (this might prevent the pins of the chip to be well connected)
 11- put back the laptop battery (5 fast blink and 2 long blinks that I got before means that the chip is not well soldered, the laptop did not find the bios)
 12- start the laptop, it should be saying invalid time...
 13- enjoy!Last edited by darkpower; 08-03-2020, 03:11 AM.Comment
 No absolutely not, the chip has no leads, so you absolutely need hot air... You can buy cheap one from china directly, I got one for 22€ delivered to my home.
 Good luckComment
			by moshuHi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
 I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
 Can you please help to remove the password?
 after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
 HP EliteBook 755 G4
 ProdID: W5Q98AV
 SN: 5CG7524BY4...-
							Channel: BIOS Requests ONLY!
			by marc_ytosGreetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...-
			by Modify_incI have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...-
- Loading...
