hp elitebook 840 g4 need password unlock
  • PawelPL
    • Feb 2020
    Re: hp elitebook 840 g4 need password unlock
    Originally posted by Vesko356
    It's specific - serials etc., so first take a good verified dump of your machine and upload the file here for unlock. After that you can write unlocked file back to the bios chip.
    Thank you, so just to clarify, as i've never done it, post the serial number & product number and that's it?
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #102
      No, not going to happen as you think. There is no software based methods, and if you want to do it - buy a programmer, the cheapest one is ch341a (10 bucks or even cheaper from ali), then read how to use it and we can talk later.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • PawelPL
        • Feb 2020
        Got it! Thank you.
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #104
          Got it!
          Thank you.
          You're welcome.
          • darkpower
            • Oct 2019
            • 13
            • France
            #105
            I have a password locked (limited lock) cannot update bios... I tried one of the bios submitted in this forum but did not work (motherboard blinking once I put in the bios), here is my password protected bios, can you please unlock it and give me one that works?
            Thanks guys
            • peste
              • 13656
              • ROMANIA
              #106
              Thanks guys
              try..
              • darkpower
                • Oct 2019
                • 13
                • France
                #107
                Hello thanks for prompt bios sending...
                Same problem, red flashing 5 times (fast) then green bkinks one time (slow blink). Could be some other issue? is it possible that I installed wrongly the chip (I'm sure I installed in the good position as it was before)?
                • peste
                  • 13656
                  • ROMANIA
                  #108
                  post the original bios not the one you tried on the site.
                  • darkpower
                    • Oct 2019
                    • 13
                    • France
                    #109
                    Hello, yes I posted the original bios from my computer not the one I downloaded from the site...
                    Regards
                    • darkpower
                      • Oct 2019
                      • 13
                      • France
                      #110
                      Originally posted by imranromi
                      Try this and reply.
                      Hello, finally it worked well thank you very much
                      Regards
                      • darkpower
                        • Oct 2019
                        • 13
                        • France
                        #111
                        Steps to flash the bios of elitebook g4 840:
                        1- Open the laptop
                        2- Remove the battery then the SSD which is very close to the bios chip
                        3- protect the surroundings of the bios with aluminium foil or kaptopn tape if you have
                        4- remove the wson8 packaged bios chip with a heat gun after putting some flux (if you don't have hot air soldering station you cannot do it!!!)
                        5- connect it to ch341a programmer using twizzers or by soldering it
                        6- make 2-3 copies of the locked bios and verify each time that the buffer & content of the chip are exactly the same (very important)
                        7- post the bios on the forum
                        8- download the unlocked bios
                        9- Erase the eeprom and write the unlocked bios
                        10- Solder the bios back on the laptop after applying flux, put more tin on the contacts and remove tin from the central one (this might prevent the pins of the chip to be well connected)
                        11- put back the laptop battery (5 fast blink and 2 long blinks that I got before means that the chip is not well soldered, the laptop did not find the bios)
                        12- start the laptop, it should be saying invalid time...
                        13- enjoy!
                        • gualancho
                          • Jul 2020
                          • mexico
                          #112
                          good morning is it possible to desolder the chip with soldering iron?
                          • peste
                            • 13656
                            • ROMANIA
                            #113
                            search for videos on the net for this issue.
                            • darkpower
                              • Oct 2019
                              • 13
                              • France
                              #114
                              No absolutely not, the chip has no leads, so you absolutely need hot air... You can buy cheap one from china directly, I got one for 22€ delivered to my home.
                              Good luck
                              • black0hackers
                                • Jul 2020
                                • 368
                                Re: Hp 840 g4 bios remove password
                                i need Main and EC bios File 840 g4
                                • peste
                                  • 13656
                                  • ROMANIA
                                  #116
                                  post the original bios and EC bios
                                  • black0hackers
                                    • Jul 2020
                                    • 368
                                    i dont have it, i need it
                                    • jaggi_32
                                      • Jul 2020
                                      • 6
                                      • India
                                      #118
                                      Request password unlock for HP Elitebook 840 G4. Attached the BIOS extract. Many thanks!
                                      • peste
                                        • 13656
                                        • ROMANIA
                                        #119
                                        try..
                                        • jaggi_32
                                          • Jul 2020
                                          • 6
                                          • India
                                          #120
                                          Doesnt work. Blank screen and 5 blinks on power button and caps lock. Checked the soldering, it is soldered well.
                                          • moshu
                                            HP EliteBook 755 G4 bios password locked
                                            by moshu
                                            Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                            I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                            Can you please help to remove the password?
                                            after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                            HP EliteBook 755 G4
                                            ProdID: W5Q98AV
                                            SN: 5CG7524BY4...
                                            02-01-2025, 06:59 AM
                                          • marc_ytos
                                            request unlock HP EliteBook 640 G11 password bios
                                            by marc_ytos
                                            Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                            01-11-2025, 06:20 PM
                                          • Modify_inc
                                            Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
                                            by Modify_inc
                                            I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
                                            11-02-2021, 11:14 AM
                                          • ibo
                                            Elitebook 655 G10 Bios Password Unlock
                                            by ibo
                                            Can somebody unlock this bios?
                                            Serial 5cd329740h...
                                            10-18-2024, 10:00 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
