hp elitebook 840 g4 need password unlock
			by moshuHi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
 I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
 Can you please help to remove the password?
 after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
 HP EliteBook 755 G4
 ProdID: W5Q98AV
 SN: 5CG7524BY4...-
							Channel: BIOS Requests ONLY!
			by marc_ytosGreetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...-
			by Modify_incI have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...-
- Loading...
