Remove_SMM... UEFI.
Re: Remove_SMM... UEFI.
Try the lenovo Autopatcher
BIOS guides, methods, resources and tools
https://www.badcaps.net/forum/showthread.php?t=103526Comment
buen dia comunidad, tengo un volcado de t490 alguien lo puede parchar o alguna manera para quitar la contraseña de este modelo ...
Good morning community, I have a t490 dump, can someone patch it or some way to remove the password from this model...
.Last edited by SMDFlea; 04-01-2023, 08:02 AM.Comment
I hope you read that carefully, everything should be fine with your BIOS file.
I just cleaned the ME region, I don't know if that will help, try it.
https://www.badcaps.net/forum/showpo...52&postcount=1
Good luck ...Last edited by SMDFlea; 04-01-2023, 08:02 AM.Comment
Just to clarify to remove bios password from a Lenovo T450
I have a Xgecu TL866 II Plus programmer, is this suitable?
Need to extract original bios making sure i have a backup and follow the instructions here - https://www.badcaps.net/forum/showpo...52&postcount=1
Basically running the patcher at the original bios file, which will make a patched bios file, which you then flash back on to the chip?Comment
Good day, I'm looking for someone in the forum who can give me information on whether he has managed to remove the password on a T495, from what I see in the messages from SmartGuru@24 and from black0hackers it seems so, I'm asking for your help as by patching the my Bios as indicated in a few previous messages I only get a series of sounds the black screen and the cpu fan that spins for a few seconds then stops, I also waited a certain time by pressing keys but no none. Thank youComment
In addition to my message, I also attach the original file and the Patch one I got, but with this I get that it doesn't work by reprogramming the eprom with the original BIOS, it works as before, protected by password. It is a Lenovo T495 version 20NK. I performed the operations with the main battery and backup battery disconnected.Last edited by SMDFlea; 04-01-2023, 08:02 AM.Comment
In addition to what is written, the T495 is equipped with an AMD Ryzen Pro 3500UComment
Hello! Can you help me please.
thinkpad a275 not working after trying to reset bios.
Black screen.
I found a clean firmware on the forum. Clear.
After starting the laptop - the Lenovo logo and reboot again.
When pressing Enter - Error 0183: Bad CRC of Security Security Settings in EFI variable.
I press F1 - and the computer restarts again.
I have a backup of the old bios - but it doesn't work.
Can you see what happened to the old backup? Or somehow transfer the data from the old backup to a clear one? I could only find the Windows serial number.Last edited by SMDFlea; 04-01-2023, 08:02 AM.Comment
T440S i7 vpro bios patch needed
i need bios patch for lenovo t440s core i7 with vpro. ihave attached the original bios with password.most files not working.Attached FilesComment
Re: T440S i7 vpro bios patch needed
You must post the serial number.You must try the methods already posted in the forum,have you tried the lenovo Autopatcher ?
.Comment
Hi Everyone,
i have a Lenovo P15v 1.Gen and i need to start from USB ( a Linux Live ). The Laptop is for my studies and now i cant boot it from other Harddiscs like USB etc.
I have check the Bios Security, but my Finger-Checkup was successful, but the password for Administrator to change the Bios Security Settings was forget ..
So i want first to ask, that the autopatcher can help on a Lenovo P15V?
I dont want to brick my Laptop :-)
Thx for ReplayComment
hello
lpm-1 mb 17870-1 ( mec1653 )
i tried autopatcher not success just Melody beeping
used the evsa patch as instructed : https://www.badcaps.net/forum/showpo...&postcount=482
TCPABIOS is missing
i need to remove password
or maybe someone has the full mec1653 firmware with the boot region
sn: R90RCF5JAttached FilesLast edited by DarkMooon; 11-20-2023, 10:55 AM.Comment
serial numberhello
TCPABIOS is missing
i need no clean password
.Comment
by nikola386Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
- Repair ticket management — Track repairs with device details, status, priority, and notes
- Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
- Customer management — Database with contact info and repair history
- Inventory tracking — Manage parts and components
- Business analytics — Real-time stats, financial overview, profit margins, and trend charts
- Professional
Channel: Announcements & Related News
Today, 02:52 PM -
by GuiTiHey everyone!
I need help with my Lenovo Chromebook 100e Gen 3.
Here are the details:- Motherboard: LA-L131P
- MFG Date: 2022/01/07
- MTM: 82J80001BR
- MO: MPNXB2103001
- Factory ID: LI123
I bought a new Winbond 25Q128FVSG chip.
The chip currently on the board is the same model but with different ending letters.
I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
The Chromebook is Google account locked, and I’ve already tried everything.
I understand that I need to replace or...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent... -
by m3vuvIts a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
07-15-2024, 10:15 AM -
by CronaxFDHey guys,
Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
From what I've... - Loading...
