Remove_SMM... UEFI.
  • AAAC
    • Jan 2020
    • 459
    • Mexico
    #1601
    Re: Remove_SMM... UEFI.
    @dgs3342
    Have you tried already to press just ENTER key when asked for KEY? AFAIK the files on this forum are patched to accept any KEY, unless you got the file from other source.
    • dgs3342
      • May 2017
      • 36
      • Italia
      #1602
      Originally posted by AAAC
      @dgs3342
      Actually I downloaded a patched bios here. It still asks me to insert a key.
      • AAAC
        • Jan 2020
        • 459
        • Mexico
        #1603
        @dgs3342
        The patched file may ask for a KEY, but may accept any KEY.
        • dgs3342
          • May 2017
          • 36
          • Italia
          #1604
          @dgs3342
          Yes, it always says invalid key
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1356
            • France
            #1605
            file mod for accept any key
            https://www.badcaps.net/forum/showpo...postcount=1296
            or patched with your original bios
            • dgs3342
              • May 2017
              • 36
              • Italia
              #1606
              Thank you very much for the help. This modified file works, I only have to insert a 7 digit key.
              The patched original locked bios doesn't work. It beeps with tpm error and LCD doesn't turn on.
              • ja5196
                • Mar 2022
                • Poland
                #1607
                Hello.
                anyone can help with the password Lenovo T440?
                TYPE 20B6-0047PB
                  • 22030
                  Originally posted by ja5196
                  Hello.
                  TYPE 20B6-0047PB
                  BIOS guides, methods, resources and tools
                  https://www.badcaps.net/forum/showthread.php?t=103526
                  • dengfz
                    • Jul 2022
                    • canada
                    #1609
                    Originally posted by dani981
                    Please feedback to me
                    I will try. my x240 had disk lock.
                    • dengfz
                      • Jul 2022
                      • canada
                      #1610
                      https://www.badcaps.net/forum/showth...=65996&page=16
                      link to the bios file
                      • wishes2022
                        • Nov 2022
                        • 38
                        • china
                        #1611
                        Originally posted by dengfz
                        please put the bios file move to here.
                        • b@w
                          • Mar 2020
                          • 33
                          • ind
                          #1612
                          Anyone can help patch for x250, this for bios backup
                          • Markus1741
                            • Sep 2020
                            • 958
                            • N/A
                            #1613
                            Try this and read this ...
                            https://www.badcaps.net/forum/showpo...52&postcount=1
                            • b@w
                              • Mar 2020
                              • 33
                              • ind
                              #1614
                              Thanks @Markus1741....this work for me
                              • syscall
                                • Nov 2022
                                • 13
                                • Swiss
                                #1615
                                Maybe someone can help me.
                                I have a Lenovo T550 with a Macronix MX25L12873L BIOS chip.
                                I created a BIOS dump using autopatcher.
                                Reading, writing, no problem.
                                When I start the notebook I hear 5x beeps 5x beeps and only see "to interrupt normal startup press enter" that was it. Enter does not work.
                                Maybe someone can edit the original dump to make it work.
                                The same Lenovo T550 with Winbond chip is no problem.
                                Here is the original dump.
                                Many Thanks
                                Hi Markus,
                                I had the same problem on a Lenovo T450s (Winbond 25Q128FV).
                                I tried the following steps:
                                1. Tape down the temper switch and remove the hard disk (I forgot it the first time).
                                2. Re-flash the patched binary and started the notebook. The patching process didn't even start ans it looked like nothing was done. Maybe because TPM was already reset. Therefore, I don't know if this step is really needed.
                                3. Re-flash the original file.
                                4. Powered-on the notebook.
                                5. After I saw it started correctly I removed the tape from the temper switch and installed the hard drive again.
                                After this steps all worked fine again.
                                I think it was just a fault of the ch341a programmer I used or simply the SOP8-clip wasn't attached perfectly to the chip while flashing back the original bios binary.
                                Behind every successful Coder there an even more successful DeCoder to understand that code - Anonymous
                                • casti3l
                                  • Mar 2014
                                  • 95
                                  • romania
                                  #1616
                                  Hello, i need to find a solution for my T480, it came with a bios password i used the autopatcher and now after i flash the original dump it makes a sound 0285 TCG-compliant functionality-related error. I atttached the original dump with password. Thank you
                                  • casti3l
                                    • Mar 2014
                                    • 95
                                    • romania
                                    #1617
                                    I finally managed to get rid of that error, i used another dump for T480 with a different version of ME, and i used the https://github.com/corna/me_cleaner to clear ME now it works fine. (i tried to clean me of the original dump but with no success.
                                    • wilkerbhz
                                      • Jul 2017
                                      • Brasil
                                      #1618
                                      Guys, I need your help, I'm a novice, and I'm in the area with a Lenovo T460-A581-MN notebook. The problem is the password in the Bios, I read several websites and forums and without success it helps me. Attached Bios Backup.
                                      • sabah
                                        • Jun 2018
                                        • 6
                                        • iraq
                                        #1619
                                        need patched bios for my thinkpad t480
                                        • siwykk
                                          • May 2020
                                          • 55
                                          • N/A
                                          #1620
                                          Try...
                                          • nikola386
                                            Introducing Repair Assistant - A Free, Open Source Management System Built for Electronics Repair Shops
                                            by nikola386
                                            Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
                                            • Repair ticket management — Track repairs with device details, status, priority, and notes
                                            • Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
                                            • Customer management — Database with contact info and repair history
                                            • Inventory tracking — Manage parts and components
                                            • Business analytics — Real-time stats, financial overview, profit margins, and trend charts
                                            • Professional
                                            Today, 02:52 PM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
