Remove_SMM... UEFI.
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    #101
    Re: Remove_SMM... UEFI.
    Try this and let me know if it works.
    • purana
      • Sep 2019
      • 14
      I'll give it a try. I'll let you know, because I believe this post was directed to my earlier one.
      Thank you for taking the time to assist. I do appreciate it.
      EDIT: can you let me know the password required to extract it?
      • RethoricalCheese
        • Mar 2013
        • 1517
        • Estonia
        #103
        For some reason I am unable to send you private message.
        Did not want others to use this file because it only works on your laptop. Password is ****.
        • purana
          • Sep 2019
          • 14
          Did not want others to use this file because it only works on your laptop. Password is xxxx
          Edit post, got it.
          EDIT: I am trying it now, will let you know results soon.
          • purana
            • Sep 2019
            • 14
            Can't even power machine up. Not sure what's going on.
            EDIT: putting original back on to confirm I can power it up again - which it was doing before I patched it. Perhaps this machine is not meant to be unlocked. I might have to let it go.
            • RethoricalCheese
              • Mar 2013
              • 1517
              • Estonia
              #106
              It can be done, I am sure. I am just new to unlocking newer Lenovos so I might not have correct files yet. I have tested only on 4 different model right now (T440s, T450, X1 carbon gen 2 and X260).
              Maybe I needed to add that fingerprint driver aswell. I will send you another file later.
              • purana
                • Sep 2019
                • 14
                Okay, sounds like a plan. Use the same password on the file I'll certainly give it a go, just putting original back on to confirm it boots. It should, reckon the patched bios was causing a problem.
                It's going to take a number of attempts I am sure. I've done it 3 times and all I got was the 5 beeps repeated so even my own attempts didn't quite work.
                • kerel
                  Banned
                  • Sep 2019
                  • 10
                  • netherlands
                  #108
                  Originally posted by kerel
                  hmmm, i cant enter private mail,
                  can you patch this bios file
                  can someone please patch this bios
                  • said7002
                    Banned
                    • Sep 2013
                    • 15
                    • maroc
                    #109
                    private message blocked hhhhhhhhhhhhhhhhhhh
                    • kerel
                      Banned
                      • Sep 2019
                      • 10
                      • netherlands
                      #110
                      yeah i dont know why
                      • RethoricalCheese
                        • Mar 2013
                        • 1517
                        • Estonia
                        #111
                        Looks like the file I sent before should work..
                        *Remove all batteries (main battery and RTC battery).
                        *Patch the bios and make sure to verify it so there aren't any errors when writing.
                        *Hold down the small switch on motherboard
                        *Connect charger (laptop should start automatically)
                        *Wait. It might even take minutes and laptop will beep/restart a few times.
                        If it still doesn't work then sorry, I don't know how to help any further.
                        • purana
                          • Sep 2019
                          • 14
                          Thanks for your help in any case..
                          • alucard6666
                            • Aug 2019
                            • 24
                            • RU
                            #113
                            My private messages is blocked too. Why?
                            Can anyone write instruction post based on experience with x40, x50 series? I havent this laptop at now.
                            • said7002
                              Banned
                              • Sep 2013
                              • 15
                              • maroc
                              #114
                              Blocked by many bad many
                              • kiknusko
                                kiknusko
                                • Jan 2019
                                • 26
                                • Slovensko
                                #115
                                Blocked by allservice.ro
                                No problem i am working on lenovotranslateservice which will accpet any key
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1517
                                  • Estonia
                                  #116
                                  You are focusing on the wrong part. Look a bit lower, outside of the box. There is an easier option to bypass.
                                  • przemek_79
                                    • Dec 2014
                                    • 28
                                    • Poland
                                    #117
                                    Hi guys
                                    Pleaseee share the lenovo translateservice file which will accept any key.
                                    • kiknusko
                                      kiknusko
                                      • Jan 2019
                                      • 26
                                      • Slovensko
                                      #118
                                      Originally posted by przemek_79
                                      Hi guys
                                      I Can unlock your ntb for free send me your BIOS dump and model
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1517
                                        • Estonia
                                        #119
                                        Well done! Did you find the spot I hinted or modified something else?
                                        • kiknusko
                                          kiknusko
                                          • Jan 2019
                                          • 26
                                          • Slovensko
                                          #120
                                          I think i find the spot you mentioned about, i changed jmp short loc_64D to short loc_64F
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hinsech475
                                            Fujitsu LIFEBOOK AH562-UEFI problem-Help request
                                            by hinsech475
                                            Hi, I would appreciate your help with the following problem.
                                            I have a Fujitsu laptop AH562 witn a BIOS-UEFI problem since I converted the HDD to a SSD. For more details on the paltop go to the following link:
                                            http://support.fujitsupc.com/CS/Port...srch=TECHSPECS
                                            After copying the HDD to SSD with ALtiris utility provided with the Kingston SSD and replacing the HDD with the SSD the laptop went into a startup loop with no screen display and only the disk LED flashing twice per second. I waited for approximatly 2h and then stopped the laptop...
                                            06-03-2018, 10:57 PM
