Remove_SMM... UEFI.
  • xaxex
    • Sep 2020
    • 24
    Re: Remove_SMM... UEFI.
    What kind of tools I should order to post my dump here? Will ch341a & a soic8 clip do the job? Do i need a special voltage adapter? 1.8V? 5V? Can someone suggest a place on the forum which is like a wiki for noobs like me
    • Aditya11ttt
      Adi
      • Feb 2019
      • 184
      • India
      #1122
      buy ch341a with clip thats all
      • alirafee
        • Jun 2015
        • 84
        • iran
        #1123
        not working sir
        • alirafee
          • Jun 2015
          • 84
          • iran
          #1124
          not working black0hackers
          tanks
          • xaxex
            • Sep 2020
            • 24
            can someone please patch this? I am unable to do it here:
            Using UEFIReplace to inject 2 DXE drivers...
            [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
            [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
            Looking for volumes to patch...
            [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
            Not found... Skipping.
            Done.
            PATCH FILE: t440p_PATCHED.bin
            Good luck.
            After flashing this, my laptop display stay blank and doesnt show anything. I hear 5 beeps after some interval
            • kicab
              • Aug 2020
              • 10
              • Poland
              #1126
              Hello! I have a password problem on Lenovo B590 (6274). I have uploaded another bios from the forum but I have a problem with detecting the Hdd disk. I also took the bios from the Lenovo update but the same problem. Can't see any hdd, sdd. As I upload the original bios with the password, it detects the disk normally. Can someone help me fix this problem?
              • xaxex
                • Sep 2020
                • 24
                Can someone please provide a patched files from original 4MB & 8MB dump with clean ME? I am on T440p laptop.
                I have supervisor password which doesnt let me change BIOS options. I need two files, which I can flash to 8MB & 4MB chips.
                • fire1234
                  • Dec 2017
                  • 77
                  • Poland
                  #1128
                  This is the bios I use, so it works 100%, I always use only 4mb of the file, 8mb almost never move, unless my region is damaged. Press F1, the password is 1234, when he asks for an ID, enter any and then follow the descriptions, good luck.
                  • xaxex
                    • Sep 2020
                    • 24
                    But this works for you? It may not work for other T440p? Right?
                    One strange thing I have noticed. When I write a ROM and then read it again, shouldn't it be same? Except it's not.
                    The file hashes doesn't match means the read file is changed from the file I am writing to chip.
                    • fire1234
                      • Dec 2017
                      • 77
                      • Poland
                      #1130
                      It works for me not only on one laptop, you have cleared my region and nvram so that it will work on every laptop, the peak files should have the same content, if there is any difference then you have a problem with the programmer and it reads the data incorrectly, it may caused by a faulty usb cable, bad grommet or the faulty programmer itself, try to read the bios content several times and compare the files together to find the correct bios, good luck.
                      • xaxex
                        • Sep 2020
                        • 24
                        read file is the same. No matter how many times I try. All hashes match for each pass/try.
                        But the file I write and then read off the chip are different. After writing file, I read from chip to verify if the file has written successfully. In this instance, the file read and file supposed to be written dont match.
                        • fire1234
                          • Dec 2017
                          • 77
                          • Poland
                          #1132
                          What programmer do you use ??, because it looks like the programmer is writing data incorrectly, it may be caused by a too long usb cable, or the programmer itself, if you had a problem with the original bios batch, I can send a clean bios, you only have to transfer the mac address ( entire GbA block). Try to program the bone until it succeeds, so that the content is the same after verification.
                          • xaxex
                            • Sep 2020
                            • 24
                            I am using CH341a.
                            Should I erase the chip and then write again?
                            • xaxex
                              • Sep 2020
                              • 24
                              FML. I am using program button to write when I just read it should be auto button. Could this be the issue?
                              Using CH341a software for CH341a programmer
                              • fire1234
                                • Dec 2017
                                • 77
                                • Poland
                                #1135
                                CH341a, and this is the cause of the problem, change the programmer, I use ezp2010, it doesn't cause as many problems as CH341a, and above all it's faster than CH341a when writing. Changing the layout will not help, just changing the programmer
                                • fire1234
                                  • Dec 2017
                                  • 77
                                  • Poland
                                  #1136
                                  Use the Auto button to first clear the layout and then save it.
                                  • xaxex
                                    • Sep 2020
                                    • 24
                                    It worked. I love you man <3. Its finally alive. The erase thing did the trick. And your bios files too.
                                    • xaxex
                                      • Sep 2020
                                      • 24
                                      After pressing space keys and turning it off, its stuck on black screen with cursor though
                                      • fire1234
                                        • Dec 2017
                                        • 77
                                        • Poland
                                        #1139
                                        do it again, before you press the space bar, wait a few seconds, at the end a message will appear that you can disconnect the power and then you need to restore the original bios, i.e. the ripped unpatched
                                        • xaxex
                                          • Sep 2020
                                          • 24
                                          Wait. what original bios? you mean the one I read off first?
                                          Do I have to flash both 8MB and 4MB file or just 4MB?
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
