Remove_SMM... UEFI.
  • Motherboard Repairs
    • May 2019
    • 63
    #621
    Re: Remove_SMM... UEFI.
    Originally posted by bogivet
    Hello, can somebody patch this bios? Lenovo T440, motherboard NM-A102. Thanks.
    Test and update make sure to reply if its working
    • bogivet
      • Aug 2015
      • 19
      • Serbia
      #622
      Not working, only 4 blinks of power switch.
        • May 2019
        • 63
        #623
        did you follow instruction above taking out battery and cmos plus holding down the litlle switch if available on board ? sometime leave for 30-60sec just charger cable
        • bogivet
          • Aug 2015
          • 19
          • Serbia
          #624
          Do you mean about dip switch before power on, or something else instructions?
            • May 2019
            • 63
            #625
            *Remove all batteries (main battery and RTC battery).
            *Patch the bios and make sure to verify it so there aren't any errors when writing.
            *Hold down the small switch on motherboard
            *Connect charger (laptop should start automatically)
            *Wait. It might even take minutes and laptop will beep/restart a few times.
            • bogivet
              • Aug 2015
              • 19
              • Serbia
              #626
              Not working, I do everything by instructions, but the same thing.
                • May 2019
                • 63
                #627
                If still same issue try this file and follow instructions above
                • stevie
                  • Apr 2010
                  • 30
                  #628
                  i have 8mb bios in T440 but i can only see 16mb
                  could i ask for help in locating 8mb DXE patch
                    • May 2019
                    • 63
                    #629
                    post your bios dump
                    • stevie
                      • Apr 2010
                      • 30
                      #630
                      here is dump
                        • May 2019
                        • 63
                        #631
                        here is dump
                        Reupload bios no good make sure to verify when reading chip
                        • stevie
                          • Apr 2010
                          • 30
                          #632
                          thanks for pointing that out
                          • bogivet
                            • Aug 2015
                            • 19
                            • Serbia
                            #633
                            This dump is ok, thank you.
                              • May 2019
                              • 63
                              #634
                              Thanks for the reply
                                • May 2019
                                • 63
                                #635
                                Check and update please
                                • Karol
                                  • May 2016
                                  • 88
                                  #636
                                  Are you sure that nobody change the BIOS chip?
                                  See post:
                                  Originally posted by Karol
                                  @CraterM
                                  @dani981
                                  I figure it out. The notebook it have 8MB flash. Probably someone try to unlock and replace the chip. Very strange that it start and ask for password. I discovered only when I change the chip
                                  So, I resolved by changing the BIOS chip, write one ME clean BIOS dump. After that I patch the new BIOS.
                                  Thanks for your efforts.
                                  Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                                    • May 2019
                                    • 63
                                    #637
                                    See post:
                                    If this is the case most likely a error will occur on screen
                                    • lalit1983
                                      • Mar 2020
                                      • 6
                                      • india
                                      #638
                                      Re: Remove psswoord
                                      please patch for password
                                      i tryied but not found bootoption in this file
                                      • CraterM
                                        • Mar 2018
                                        • 178
                                        • Moldova
                                        #639
                                        Re: Remove psswoord
                                        Because not read correctly
                                        • lalit1983
                                          • Mar 2020
                                          • 6
                                          • india
                                          #640
                                          i patched
                                          it go to hw id
                                          password when pressing enter or space two time
                                          no response
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
