Remove_SMM... UEFI.
  • skytelckua
    • Mar 2020
    • Ukraine
    #521
    Re: Remove_SMM... UEFI.
    Please help with T440 NM-A102 (VIVL0)
    • Ghamidi
      • Mar 2020
      • 303
      • France
      #522
      try this file with any key
      • leva2407
        • Jul 2016
        • 89
        • tbilisi
        #523
        please help me to unlock my x1 carbon 2gen
        • Karol
          • May 2016
          • 88
          #524
          Waiting your feedback. Enjoy !
          Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
          • leva2407
            • Jul 2016
            • 89
            • tbilisi
            #525
            its realy working thanks
            • leva2407
              • Jul 2016
              • 89
              • tbilisi
              #526
              thanks
              • skytelckua
                • Mar 2020
                • Ukraine
                #527
                works!
                Thanks!
                • slaine
                  • Feb 2020
                  • 21
                  • germany
                  #528
                  Hi there, after my request for the cleaning of a Yoga360 in an extra Post was fullfilled, I found this Thread. I wanted to try this process by myself with an T570. I compiled all the data i found in this thread and created a patched dump. Here is what I did:
                  - exchanged the xxxtranslate and bootxxx in UEFI-Tool with the patched xxxtranslation (posted as patched single file)and the bootxxx from the 3-file-package.
                  - modified the two VSS2, FTW and EVSA regions as described on page 26 with HxD (my EVSAStore started @Base 890000 instead of 880000 in UEFITool a57)
                  - flashed the patched dump
                  - removed everything battery wise
                  - double checked soldering points
                  - switch pressed, power supply in
                  leads to Lenovo Screen followed by:
                  "0271: check date and time"
                  "0251: system cmos checksum bad..."
                  "0183: Bad CRC of Security Settings in EFI variable"
                  Press F1 to enter Setup
                  F1 leads to System Shutdown, repeat xN
                  Leaving it on for about 10 Minutes no changes. Maybe somebody can look into the patched_dump I created to check what I was doing wrong
                  • CraterM
                    • Mar 2018
                    • 178
                    • Moldova
                    #529
                    Try another modified dump from here! Search in this topic!
                    • slaine
                      • Feb 2020
                      • 21
                      • germany
                      #530
                      Thank you - it worked. But I also got the
                      Errors there, after 5 Minutes of waiting it worked, still dont know what I was doing wrong with the patching maybe the patched lenovotranslate should be the one from the 3-file-package, not the single posted one...
                      • CraterM
                        • Mar 2018
                        • 178
                        • Moldova
                        #531
                        When using another dump, it takes longer. Even so in some cases it doesn't work!
                        • franco00
                          • Jun 2014
                          • italy
                          #532
                          Hello!
                          Can someone help with BIOS patch for attached x260 NM-A531?
                          • franco00
                            • Jun 2014
                            • italy
                            #533
                            Sorry
                            • Ghamidi
                              • Mar 2020
                              • 303
                              • France
                              #534
                              Originally posted by franco00
                              Sorry
                              • franco00
                                • Jun 2014
                                • italy
                                #535
                                Thank you
                                All works
                                • bachir2004
                                  • Feb 2015
                                  • 439
                                  • maroc
                                  #536
                                  Can somebody please help me remove svp lenovo a475.
                                  • CraterM
                                    • Mar 2018
                                    • 178
                                    • Moldova
                                    #537
                                    Please confirm if it works!
                                    I made another A475 and it sounds like it didn't work!
                                    • vampel
                                      • May 2018
                                      • 7
                                      • Mexico
                                      #538
                                      Originally posted by HungSoi
                                      I guess there is P24S08 or L08 EEPROM on thinkpad L440 motherboard. If you can find out this EEPROM, you can unlocked yours.
                                      Watching this link (https://www.youtube.com/watch?v=ANZjUPUYE7s).
                                      P/S: I used to unlock Thinkpad L540 (not thinkpad L440) via this menthod. I attached "L08 EEPROM location" on Thinkpad L540.
                                      Good luck to you.
                                      hi. i do all steps and pass gone but computrace still, theres another way to remove it?
                                      • vampel
                                        • May 2018
                                        • 7
                                        • Mexico
                                        #539
                                        i have read all this post but i have a question.. what program use to upload the .rom or u se a programmer like ch341a? ps. have a rt809
                                        • D'Bryte
                                          • Dec 2018
                                          • 32
                                          • Africa
                                          #540
                                          Someone pls help patch this bios for me...there's password in it...thanks in advance
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
