Remove_SMM... UEFI.
  • lap12
    • Mar 2019
    • 40
    Re: Remove_SMM... UEFI.
    t440s please send me patched file
    • Amit sharma
      • 5
      • India
      #602
      Pls Check And reply
      • lap12
        • Mar 2019
        • 40
        t470p send me unlock file
        • Motherboard Repairs
          • May 2019
          • 63
          #604
          Try this file and update please
          *Remove all batteries (main battery and RTC battery).
          *Patch the bios and make sure to verify it so there aren't any errors when writing.
          *Hold down the small switch on motherboard (IF AVAILABLE)
          *Connect charger (laptop should start automatically)
          *Wait. It might even take minutes and laptop will beep/restart a few times.
          • johnli1111
            • Apr 2020
            • 5
            Can you please help with this T460 bios file? Thank you so much.
            • CraterM
              • Mar 2018
              • 178
              • Moldova
              #606
              Read again, this file is damaged!
              • MAZMAZ22
                • Jul 2016
                • 68
                • ALGERIE
                #607
                t460 please send me patched file
                  • May 2019
                  • 63
                  #608
                  • johnli1111
                    • Apr 2020
                    • 5
                    Hi CarterM and motherboard repair, is there anyway to try to extra info off the damaged file? I overwrote the bios and that's the only file I have.
                    • johnli1111
                      • Apr 2020
                      • 5
                      I had this other read initial, but don't know if it's also have issue.
                      Thank you so much for any help.
                        • May 2019
                        • 63
                        #611
                        • johnli1111
                          • Apr 2020
                          • 5
                          Hi Motherboard Repair, I flashed both files and the T460 beeps 5 times with no display.
                            • May 2019
                            • 63
                            #613
                            Did you follow procedure below ? is this the original dump ?
                            1. Remove The Battery CMOS . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new Lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have NO The main Battery attached and the NO Battery CMOS .
                            2. Insert other LOCK HDD OR SSD M.2 ( by the way use another laptop set up password lock HDD and remember your password )
                            3. ReFlash BIOS with patched file
                            4. The First Step Let Press Down and Still Keep Little Switch ( picture attached ) long time and The Second Step Let Plug in the AC adapter and wait for a few seconds, the laptop will start by itself (if not, press the Power button and start it). You may hear some beeps then you will see the Lenovo splash image, press F1 to get the SVP password prompt and enter "1234" for SVP and press Enter. Next page will showing "Press any key..". Wait about 10 to 12 seconds before pressing any Key. Next it will display the warning message and the laptop hardware ID. Do not disconnect the AC during this process!
                            if still same try these files first zip is your files second zip custom
                              • May 2019
                              • 63
                              #614
                              If 2x 5beep, it's normal.
                              Wait minimum 30sec before screen logo light on. Must turn on/off several times by itself
                              • johnli1111
                                • Apr 2020
                                • 5
                                The unlocked files didn't work. They didn't boot except for beeping and completely blank on the display. I followed all the instruction.
                                The T460 custom files patched does flash, but it'll have the error 0183: Bad CRC of Security Settings in EFI variable.
                                Pressing F1 goes to a blank screen, it doesn't work after that.
                                CraterM, here's a new read of the original chip as you requested. Thank you for any help.
                                • rbnote
                                  • Nov 2013
                                  • 83
                                  • brazil
                                  #616
                                  Hi guys, can you help this files, I try but t440 power off when digit pass 1234
                                    • May 2019
                                    • 63
                                    #617
                                    Try this file 99% sure it will work please update me
                                      • May 2019
                                      • 63
                                      #618
                                      Test and update
                                      • AAAC
                                        • Jan 2020
                                        • 458
                                        • Mexico
                                        #619
                                        Have only done a few thinkpad unlocks, but in my experience if the computer freezes after pressing F1 and goes to a blank screen, it means that supervisor password is NOT set. You may only have a power-on password set, which can be cleared by disconnecting cmos battery and internal battery (if any), leave them disconnected for at least one minute and then put them back.
                                        If you are experiencing the blank screen after pressing F1, can also try to use a locked hard drive, that will make the patch work.
                                        ... my two cents.
                                        • bogivet
                                          • Aug 2015
                                          • 19
                                          • Serbia
                                          #620
                                          Hello, can somebody patch this bios? Lenovo T440, motherboard NM-A102. Thanks.
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
