Remove_SMM... UEFI.
  • SD tech
    • May 2017
    • 13
    • ghana
    #481
    Re: Remove_SMM... UEFI.
    It works bro , thank you dani981 and mr. Qurash
    • bsz
      • Feb 2020
      • 5
      #482
      First extract as is with UEFITool (use search) Lenovotranslateservice and Bootoption.
      Replace as is Lenovotranslateservice and Bootoption with the files you extracted.
      If you have black screen or freeze try ctrl+alt+del or power on/off few times. If not working try with a hdd with password.
      If you get no image and 5 beeps:
      Use a hex editor and fill with ff the following files:
      VSS2 store Data address: 800064h Body size: 26F9Ch
      VSS2 store Data address: 82701Ch Body size: 26FE4h
      FTW store Data address: 84E020h Body size: 1FE0h
      (ex. from address 800064h to address 800064h + 26F9Ch fill with FF)
      and replace EVSA store Base address: 880000h size: 20000h with the file attached .
      You can check the address and size in your bios dump with uefitool.
      Follow the post from dani981 post 490.
      • benz2002
        • Jul 2013
        • 8
        • Philippines
        #483
        hi Bro, i really want to follow your instruction but how come i didn't see any "EfiSystemNvDataFvGuid" in the BIOS Region
        • Ghamidi
          • Mar 2020
          • 303
          • France
          #484
          hello
          need patched bios file Thinkpad A475 CPU. AMD PRO A12
          Thank you
          • bsz
            • Feb 2020
            • 5
            #485
            Use Uefitool 0.27.0 for replacing the 2 files and Uefitool A56 to see or comfirm the address.
            • dirigjenti29
              • Apr 2018
              • 20
              • alb
              #486
              Originally posted by dani981
              Overheating. CPU fan clean? Bios update https://support.lenovo.com/us/en/downloads/ds035965Motherboard serial no? For example:T440S
              VILTO NM-A051 REV: 1.0
              cpu fan is clean,serial board is VILTO NM-A052 REV: 1.0 i try change ssd with a new one.
              • RethoricalCheese
                • Mar 2013
                • 1514
                • Estonia
                #487
                There is no need to wait 10-15 seconds before pressing enter when hardware ID is bypassed. Stop wasting your time
                • dani981
                  • Mar 2018
                  • 89
                  • Hungary
                  #488
                  hi
                  check HDD, RAM!!
                  another bios try it.
                  • RethoricalCheese
                    • Mar 2013
                    • 1514
                    • Estonia
                    #489
                    Hey!
                    Having trouble with these X1 Yoga Gen 1 models. Either just 5 beeps no display or when I do get display, it will always restart after pressing F1.
                    • dirigjenti29
                      • Apr 2018
                      • 20
                      • alb
                      #490
                      hi
                      check HDD, RAM!!
                      this bios is 8mb,the org bios is 16 mb.i check ram and ssd,its ok,i try without any drive and its the same problem.If i try to write mec 16xx can you help me with schematic pin connection and a good bin for EC MEC 16xx?thank you very much,i aprachiate!
                      • dani981
                        • Mar 2018
                        • 89
                        • Hungary
                        #491
                        Originally posted by RethoricalCheese
                        Hey!
                        Patched this file.
                        Well, maybe good.
                        Please feedback to me.
                        • dani981
                          • Mar 2018
                          • 89
                          • Hungary
                          #492
                          Excuse me.Dont see size file
                          Goood ec file plus 1633 ec connect j tag pdf
                          • Karol
                            • May 2016
                            • 82
                            #493
                            Hello!
                            Can someone help with BIOS patch for attached T440?
                            Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                            • dani981
                              • Mar 2018
                              • 89
                              • Hungary
                              #494
                              Originally posted by Karol
                              Hello!
                              • RethoricalCheese
                                • Mar 2013
                                • 1514
                                • Estonia
                                #495
                                Patched this file.
                                Well, maybe good.
                                Hey! Already tried with 100% identical file. It will always restart after pressing F1.
                                • CraterM
                                  • Mar 2018
                                  • 171
                                  • Moldova
                                  #496
                                  Try
                                  • Karol
                                    • May 2016
                                    • 82
                                    #497
                                    Hello and thank you for the reply.
                                    It's acting strange... when I program the flash chip it give me an error every time to the same address 0x400058 when verify the programming.
                                    If I start the notebook with how it is programmed it give me 5x5 beeps.
                                    When I program the original file it work perfectly, verify is correct.
                                    So I start again the notebook with password, only to check to see is OK, and it is.
                                    Now I let the motherboard more time to discharge and read again the flash.
                                    Can you try patching again this file?
                                    • CraterM
                                      • Mar 2018
                                      • 171
                                      • Moldova
                                      #498
                                      Try
                                      • dirigjenti29
                                        • Apr 2018
                                        • 20
                                        • alb
                                        #499
                                        thank you very much for all your time i solve it.
                                        • Karol
                                          • May 2016
                                          • 82
                                          #500
                                          @CraterM
                                          @dani981
                                          I figure it out. The notebook it have 8MB flash. Probably someone try to unlock and replace the chip. Very strange that it start and ask for password. I discovered only when I change the chip
                                          So, I resolved by changing the BIOS chip, write one ME clean BIOS dump. After that I patch the new BIOS.
                                          Thanks for your efforts.
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hinsech475
                                            Fujitsu LIFEBOOK AH562-UEFI problem-Help request
                                            by hinsech475
                                            Hi, I would appreciate your help with the following problem.
                                            I have a Fujitsu laptop AH562 witn a BIOS-UEFI problem since I converted the HDD to a SSD. For more details on the paltop go to the following link:
                                            http://support.fujitsupc.com/CS/Port...srch=TECHSPECS
                                            After copying the HDD to SSD with ALtiris utility provided with the Kingston SSD and replacing the HDD with the SSD the laptop went into a startup loop with no screen display and only the disk LED flashing twice per second. I waited for approximatly 2h and then stopped the laptop...
                                            06-03-2018, 10:57 PM
