Remove_SMM... UEFI.
  • dirigjenti29
    • Apr 2018
    • 20
    • alb
    #461
    Re: Remove_SMM... UEFI.
    i try to install ubuntu and show me this problem,please replay me if it can be fix?!!!!
    • dani981
      • Mar 2018
      • 89
      • Hungary
      #462
      Overheating. CPU fan clean? Bios update https://support.lenovo.com/us/en/downloads/ds035965Motherboard serial no? For example:T440S
      VILTO NM-A051 REV: 1.0
      • MOTechGuy
        • Mar 2020
        I have my three laptops that I'm having trouble with patching... A T580, a T470, and an X1 carbon gen 3. I've tried the available files here too, with no success.
        I'm able to read and write the original files, and they boot as usual.
        Could someone please help?
        • MOTechGuy
          • Mar 2020
          Apologies for the double post, but I was successful in creating a patch for the T470. Still no luck on the carbon or 580.
          • MR.Qurash
            • Mar 2020
            • 5
            • Kazakhstan
            #465
            Good afternoon ! who can fix my dump my bios dump. after replacing the files I received 5 beeps and the inscription press f1, after pressing the black screen, I drop the original, no change, please help!
            • dani981
              • Mar 2018
              • 89
              • Hungary
              #466
              Please feedback to me.
              • dani981
                • Mar 2018
                • 89
                • Hungary
                #467
                • MOTechGuy
                  • Mar 2020
                  100% working, thank you!
                  • MR.Qurash
                    • Mar 2020
                    • 5
                    • Kazakhstan
                    #469
                    THANKS A LOT !!!!! Daniel Dumps Workers! I really appreciate your help !!!
                    • tamilnilan
                      • Dec 2018
                      • 16
                      • France
                      #470
                      hi,Please can you patch for me x270 need to remove password and if you can need clear me please.thank you!
                      • SD tech
                        • May 2017
                        • 14
                        • ghana
                        #471
                        thanks sir for a quick reply.
                        below is the dump file in reference to the earlier requet i made
                        on lenovo thinkpad t480s
                        Machine manufacturer: LENOVO
                        Product name: 20L7002KUS
                        Product version: ThinkPad T480s
                        Serial number: PC0WJQ22
                        BIOS INFORMATION
                        BIOS Version: N22ET59W (1.36 )
                        BIOS release date: 10/18/2019
                        BIOS manufacturer: LENOVO
                        • CraterM
                          • Mar 2018
                          • 178
                          • Moldova
                          #472
                          Try
                          • CraterM
                            • Mar 2018
                            • 178
                            • Moldova
                            #473
                            Try
                            • dani981
                              • Mar 2018
                              • 89
                              • Hungary
                              #474
                              • dani981
                                • Mar 2018
                                • 89
                                • Hungary
                                #475
                                BIOS INFORMATION
                                • Miuku
                                  • Feb 2020
                                  • Finland
                                  #476
                                  At first I have to thank you all of you guys here for all of this work. I have no programming skills and I just have tested some of your artwork. There is one question that I´m wondering. I have tested same (patched) dump for same computer many times. Sometimes it works, sometimes it doesn`t. I`ve tested this with x240 and t440p machines (their own patches ofcourse). Programming goes well and verifying ok but sometimes patch is halted somewhere. I program original bios and then try patch again and it (usually)works. Weird?
                                  • dani981
                                    • Mar 2018
                                    • 89
                                    • Hungary
                                    #477
                                    Instrucion for everyone
                                    1. Remove The Battery CMOS . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new Lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have NO The main Battery attached and the NO Battery CMOS .
                                    2. Insert other LOCK HDD OR SSD M.2 ( by the way use another laptop set up password lock HDD and remember your password )
                                    3. ReFlash BIOS with patched file
                                    4. The First Step Let Press Down and Still Keep Little Switch ( picture attached ) long time and The Second Step Let Plug in the AC adapter and wait for a few seconds, the laptop will start by itself (if not, press the Power button and start it). You may hear some beeps then you will see the Lenovo splash image, press F1 to get the SVP password prompt and enter "1234" for SVP and press Enter. Next page will showing "Press any key..". Wait about 10 to 12 seconds before pressing any Key. Next it will display the warning message and the laptop hardware ID. Do not disconnect the AC during this process!
                                    • SD tech
                                      • May 2017
                                      • 14
                                      • ghana
                                      #478
                                      i patched lenovo thinkpad t480s for bios password
                                      patch was successful and
                                      i'm getting 10 digit hardware id
                                      Hardware id : 1593504162
                                      can anyone generate the key?
                                      if any one has key generator , kindly share as it can help
                                      • MR.Qurash
                                        • Mar 2020
                                        • 5
                                        • Kazakhstan
                                        #479
                                        SD Tech. look at the post 490 from Deni981 he described how and what to do, only after receiving the ID you need to wait a bit for 10-15 seconds, then press ENTER, after asking to press SPACE 2 times, after it displays a message that you can turn off the power, roll up chip your Bios dump that was password-protected, you start the laptop without batteries, it should start with an error ITEM TIME, press F1, adjust the BIOS settings, turn off the laptop, connect the batteries and the power supply, and you will be happy
                                        • Ghamidi
                                          • Mar 2020
                                          • 305
                                          • France
                                          #480
                                          hi
                                          any key friend
                                          1234567
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
