Remove_SMM... UEFI.
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    #221
    Re: Remove_SMM... UEFI.
    anyone pached bios for t440p??
    i try this method, but laptop goes off after press f1
    https://www.badcaps.net/forum/showth...708#post932708
    • 530v8
      • May 2019
      • 39
      Originally posted by RethoricalCheese
      Find lenovotranslateservice and then scroll up or down from it, there will be only one bootoption.
      Will try that
      Somebody can repair bios file from t450s?
      Repair because short sdl and sda now it's not booting anything
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #223
        Eeprom is SPI. What I2C device did you try shorting then?
        • 530v8
          • May 2019
          • 39
          short it with screwdriver
          but bios chip is ok cause flash rom can find and flash other bios dumps
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #225
            WHAT device did you try shorting? Bios chip is SPI so it doesn`t have sda/scl.
            • 530v8
              • May 2019
              • 39
              I short the winbond bios chip
              • 530v8
                • May 2019
                • 39
                problem solved thanks to Maxpower3 and all others, now I can help too
                by the way I can do it for hp if somebody wants to free up his bios
                elitebook zbook probook folio etc
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1356
                  • France
                  #228
                  So this is the LenovoTranslateService file I patched so it would accept any key.
                  I did test it on X260 and it did work well. But when I tested it on X270, there would be beeps but no display.
                  I know that 6th, 7th and 8th gen share the same LenovoTranslateService and BootOptions file (I compared patched files for different models). There may be another file needed ?!
                  I have 7th gen files that I bought on ebay. It works with generator and they are validated by checksum or rsa key. Unable to change the bit for the unlock. After analysis I see that the file is clean and not just patching.
                  https://ibb.co/DGj0pnk
                  • aijazali
                    • 124
                    • saudi arabia
                    #229
                    hi all friends can any one patch lenovo thinkpad t450 NM-A251 rev 1.0
                    bypass pasword need bin file patched
                      • 22030
                      You`ve asked in 3 seperate threads for the same thing,why don`t you wait for a reply in this thread ?
                      • georgios22
                        • 14
                        • b
                        #231
                        Can someone patch me E580 BIOS ?
                        The patch i did doens't seem to work... (attached if anyone wants to take a look) it only makes a funny noise
                        • mohamedxp
                          Banned
                          • Jul 2014
                          • 29
                          • algiers
                          #232
                          hello friends
                          pls need patched bios for thinkpad L560
                          thank you
                          • georgios22
                            • 14
                            • b
                            #233
                            I patched my own bios but i get error 0285: TCG-compliant functionality-related error (might be
                            the TPM initialization failure)
                            Any help ?
                            • mohamedxp
                              Banned
                              • Jul 2014
                              • 29
                              • algiers
                              #234
                              hello
                              need patched my orginal bios file
                              thank you
                              • georgios22
                                • 14
                                • b
                                #235
                                Originally posted by mohamedxp
                                hello
                                thank you
                                First time patching, but i think i got it.
                                Try this file
                                • mohamedxp
                                  Banned
                                  • Jul 2014
                                  • 29
                                  • algiers
                                  #236
                                  [QUOTE=georgios22;933702]First time patching, but i think i got it.
                                  Try this file[/
                                  THANK YOU VERY MUCH WORKING 100%
                                  • mohamedxp
                                    Banned
                                    • Jul 2014
                                    • 29
                                    • algiers
                                    #237
                                    Originally posted by georgios22
                                    first time patching, but i think i got it.
                                    Try this file
                                    thank you very much working 100%
                                    • hruskavlasto
                                      • Oct 2017
                                      • 9
                                      • Bratislava
                                      #238
                                      pls patch bios for thinkpad L460
                                      • hruskavlasto
                                        • Oct 2017
                                        • 9
                                        • Bratislava
                                        #239
                                        NJECT WORK 100% unlocked: T440 L460
                                        • mohamedxp
                                          Banned
                                          • Jul 2014
                                          • 29
                                          • algiers
                                          #240
                                          Originally posted by hruskavlasto
                                          nject work 100% unlocked: T440 l460
                                          unlocked without keygen ??
                                          • nikola386
                                            Introducing Repair Assistant - A Free, Open Source Management System Built for Electronics Repair Shops
                                            by nikola386
                                            Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
                                            • Repair ticket management — Track repairs with device details, status, priority, and notes
                                            • Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
                                            • Customer management — Database with contact info and repair history
                                            • Inventory tracking — Manage parts and components
                                            • Business analytics — Real-time stats, financial overview, profit margins, and trend charts
                                            • Professional
                                            Today, 02:52 PM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
