Remove_SMM... UEFI.
  • iTec
    • Oct 2017
    • 32
    Re: Remove_SMM... UEFI.
    Thank you for the reply and the help. With this DUMP, no image, no Melodic sound.
    Machine type 20LN 20LM.
    • Ljubisa2707
      • Nov 2019
      • 6
      • Bosnia and hercegovina
      #362
      Write your original (lock bios dump) , and find on board eeprom (24rf08 ps08 or 08 8pin) in this eeprom is bios password, you must reflash this chip to remove svp pasword
      • mjalil28
        Banned
        • Oct 2015
        • 45
        Hardware id : 4657417
        can anyone generate the key
        • bjhawfam
          • Dec 2014
          • 144
          Looking for help would prefer to learn more than someone else performing the patch. I'm working on a L470, when I replace pe32 OR the entire file in both LenovoTranslateService and BootOption I get the same result. Melodic sound that translates into code 0285 (TPM initialization failure). I'm using UEFI tool and using the replace option. Just a little nudge in the right direction would be helpful. Thanks in advance.
          • bjhawfam
            • Dec 2014
            • 144
            By the way here's a file from the original bios that I tried replacing the files. Does it look correct?
            • xdrive55
              • Feb 2020
              • Belarus
              #366
              Hi, please help with t460s bios.
              • bjhawfam
                • Dec 2014
                • 144
                Still not correct, same melodic tune (beeps).
                I have quite a few Lenovo's on hand, I'll try a T550 and a T450s. Both are currently unlocked, I'll create an SVP and test those out.
                Think I figured out my mistake in replacing the file, will try later today and report back........!!!
                • fyaagoub
                  • 269
                  • maroc
                  #368
                  Can someone patch this file for me to unlock bios for lenovo t490 I5 8TH GENE THANKS?
                  • onizzbox
                    Banned
                    • Nov 2018
                    • 604
                    • Brazil
                    #369
                    Please feedback to me
                    • onizzbox
                      Banned
                      • Nov 2018
                      • 604
                      • Brazil
                      #370
                      • xdrive55
                        • Feb 2020
                        • Belarus
                        #371
                        Thanks.All ok.
                        • cayenne
                          • Jul 2017
                          • 19
                          • Eesti
                          #372
                          Can anyone patch this t440, other rom faound in this forum did not work.
                          • fyaagoub
                            • 269
                            • maroc
                            #373
                            please feedback to me
                            patch not done
                            • bjhawfam
                              • Dec 2014
                              • 144
                              I've tried several attempts and still come up empty handed. Can someone please patch this file for me. Thanks
                              • xdrive55
                                • Feb 2020
                                • Belarus
                                #375
                                Try
                                • bjhawfam
                                  • Dec 2014
                                  • 144
                                  Hello, Yes it worked and thank you. I was able to compare the files and found my LenovTranslateService was the same. The BootOption was the same as well. What am I doing wrong?
                                  • bjhawfam
                                    • Dec 2014
                                    • 144
                                    Try
                                    When I compare lenovotranslateservice and bootoption they come out the same in hex editor extract. Why does the patch I created not work compared to yours?
                                    NEVERMIND I found it.. I was able to compare several files on here and found the changes.
                                    FINALLY!!!! After comparing the files and using both a hex editor and UEFITool I was able to find my problem. I then used the original file and made a patch as well. When I run a comparison it comes back exactly as the patch xdrive55 created. Just had to replace one last region and BAM.. Will have to try it out. Thanks for your help xdrive55 and for all who posted in this tread that contributed.
                                    • teqcom
                                      • Nov 2015
                                      • 311
                                      • malasyia
                                      #378
                                      hi patche for me this file t440p
                                      • dani981
                                        • Mar 2018
                                        • 89
                                        • Hungary
                                        #379
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #380
                                          patch not done
                                          Because T490 is not supported.
                                          • nikola386
                                            Introducing Repair Assistant - A Free, Open Source Management System Built for Electronics Repair Shops
                                            by nikola386
                                            Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
                                            • Repair ticket management — Track repairs with device details, status, priority, and notes
                                            • Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
                                            • Customer management — Database with contact info and repair history
                                            • Inventory tracking — Manage parts and components
                                            • Business analytics — Real-time stats, financial overview, profit margins, and trend charts
                                            • Professional
                                            Today, 02:52 PM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
