Remove_SMM... UEFI.
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    #41
    Re: Remove_SMM... UEFI.
    Originally posted by alucard6666
    imranromi Please, send me your BIOS image, i try to program keygen for you.
    i have all lenovo algorithm generate key so i use different algorithm solve my problem
    • Marian97
      • Sep 2019
      • 13
      #42
      I've tried the DXE driver found on this thread called 2E.zip but it doesn't do anything.
      The system turns on like before throwing the error 0199. The thing that is different is that when I press F1 in order to show me the screen for supervisor password, the system turns off.
      Do you have any idea? Can someone help me inject a allservice DXE driver into my bios dump please? Or at least upload a good DXE driver here.
      Thanks!
      • alucard6666
        • Aug 2019
        • 24
        • RU
        #43
        You need inject not only lenovotranslateservice, but translateservice + other files(I do not know witch file excatly). 2E.zip (lenovotranslateservice) is only interface of allservice patch, all work doing in other files.
        • alucard6666
          • Aug 2019
          • 24
          • RU
          #44
          I need lenovotranslateservice or BIOS image that you used, to see algorithm that generate key. I try to disassembly lenovotranslateservice to see algorithm, then write keygen.
          • Marian97
            • Sep 2019
            • 13
            #45
            So what are the other files? Do you have them?
            • said7002
              Banned
              • Sep 2013
              • 15
              • maroc
              #46
              extract dxe drive from bios pathched
              • Marian97
                • Sep 2019
                • 13
                #47
                Ok, so things are getting a little messy around here.
                Let me check if what I know and understand is right.
                I have my bios dump from my locked X250 called, let's say original.bin.
                I have two files from this thread called 2e and pe32_image... Etc
                I replaced my lenovotrabslateservice with both of them, one at a time and none worked. Not even the allservice branding at boot.
                So now you are telling me that lenovotranslateservice is not the only dxe driver that needs to be replaced, and that I should get the other one from a patch bios?
                Which is this patched bios and what are the other dxe drivers I need to extract from them?
                • alucard6666
                  • Aug 2019
                  • 24
                  • RU
                  #48
                  1. You do not need replace lenovotranslateservice twice. Only one file should be used(2E or pe32_image).
                  2. All password reset work takes place in BootOption section.
                  I think to patch BIOS you need at least 3 files: lenovotranslateservice, BootOption, SystemPipsNeededbyDXE core.
                  I try to patch BIOS, but... something wrong with GUID. My laptop freeze after enter right key.
                  • alucard6666
                    • Aug 2019
                    • 24
                    • RU
                    #49
                    You have working solution?
                    • Marian97
                      • Sep 2019
                      • 13
                      #50
                      I didn't replaced lenovotranslateservice twice. I tried both files separately an none of them worked because you said there should be more of them.
                      What BIOS did you tried to patch?
                      Do you have the other files needed?
                      • alucard6666
                        • Aug 2019
                        • 24
                        • RU
                        #51
                        Try this:
                        https://drive.google.com/open?id=1n_...mFiSbL5i8m7vZu
                        • Marian97
                          • Sep 2019
                          • 13
                          #52
                          Thank you! I will try it tonight.
                          I see there are fbd files. Do I replace only the Pe32 image or the whole module?
                          I suppose the whole module because pe32 images are efi files.
                          • alucard6666
                            • Aug 2019
                            • 24
                            • RU
                            #53
                            You can extract modules from you BIOS with whole or PE32 body option and see differents in WinDIFF, and then decide. Or try to both metod)
                            • Marian97
                              • Sep 2019
                              • 13
                              #54
                              It didn't worked. It booted like before, the same 0199 error, nothing changed.
                              Did it worked for you?
                              I replaced the 3 files using Replace body option in EFITool and then flashed the bios back to the chip. Nothing change.
                              Did I forget to do something?
                              • alucard6666
                                • Aug 2019
                                • 24
                                • RU
                                #55
                                What 199 error means?
                                You can try this instruction from allservice:
                                1. Make sure CMOS is cleared by removing the 3V cell completely. Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new Lenovo may have an internal battery, the black box) by removing its connector from the motherboard.
                                It is important that the laptop will have NO battery attached.
                                2. Plug in the AC adapter and wait for a few seconds, the laptop will start by itself (if not, press the Power button and start it). You may hear some beeps then you will see the Lenovo splash image, quickly press F1 to get the SVP password prompt and enter "1234" for SVP and press Enter.
                                Tip: If the laptop beeps and the power stays ON but there's no display then a quick fix is to insert a locked HDD in the laptop and start again.
                                The HDD must be ATA locked (in another laptop or in this one, has no importance) and this will force our DXE security module to load and the BIOS will start.
                                Next page will show you Allservice DXE driver loading and showing "Press any key..". Wait about 20-30 seconds before pressing a key.
                                Next it will display the warning message and the laptop hardware ID. At this moment, press CTRL-ALT-DEL to do a warm reboot.
                                Do not disconnect the AC during this process!
                                3. Now repeat as in step 2: Press F1 to get the SVP prompt and enter "1234", then wait about 20-30 seconds before pressing any key and generate the hardware ID again.
                                Write down this hardware ID and email it to us. While waiting to receive the response key form us, DO NOT TURN OFF the laptop and DO NOT PRESS ANY KEY!
                                • Marian97
                                  • Sep 2019
                                  • 13
                                  #56
                                  All right, it seems like it does what you say if I enter the 1234 password. Let me do exactly like you said and I'll come back with the hwid in a couple of minutes.
                                  Thank you!
                                  • Marian97
                                    • Sep 2019
                                    • 13
                                    #57
                                    0199 system security - security password retry count exceeded
                                    This is the error you get when you enter the wrong SVP password too many times. Then you get locked out of the system. You can't access the BIOS or anything else.
                                    • Marian97
                                      • Sep 2019
                                      • 13
                                      #58
                                      OK, I did as you said, the Hardware ID is 6401946
                                      • drgn997
                                        Banned
                                        • Dec 2011
                                        • 19
                                        #59
                                        @Marian97
                                        Check PM.
                                        • alucard6666
                                          • Aug 2019
                                          • 24
                                          • RU
                                          #60
                                          Sorry, but I dont have keygen for 7 digits HW ID, I only have for 9 digits HW ID. Try to inject other lenovotranslateservice shared in this thread, link https://drive.google.com/open?id=13n...WtACdXwTcaTjPP I already shared my keygen in this thread.
                                          • nikola386
                                            Introducing Repair Assistant - A Free, Open Source Management System Built for Electronics Repair Shops
                                            by nikola386
                                            Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
                                            • Repair ticket management — Track repairs with device details, status, priority, and notes
                                            • Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
                                            • Customer management — Database with contact info and repair history
                                            • Inventory tracking — Manage parts and components
                                            • Business analytics — Real-time stats, financial overview, profit margins, and trend charts
                                            • Professional
                                            Today, 02:52 PM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
