plzz need bios file for Emachines e625
  • WINJOKE
    Banned
    • Jan 2014
    • 27
    i hop if someone can help i need a bios file for these manbaord
    p/n LA-4861P REV 1.0 GRAPHIQUE CARD IS AMD
  • WINJOKE
    Banned
    • Jan 2014
    • 27
    Re: plzz need bios file for Emachines e625
    Look like is not easy to get thèse file ��
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      alsalam alykoum
      here is ....mashoub
      Tafadal
      • saularciga
        • Feb 2014
        • 55
        • mexico
        Not open!!, I not can open it
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
