HP Elitebook 840 G2
  • technog0d
    • Oct 2017
    • 6
    • usa
    HP Elitebook 840 G2
    I have a HP elitebook 840 g2 that i am trying to reset the password for the bios on. I have a ch341a programmer and i am using version 1.30 of the software. It reads and verifys ok. However, the file is only 2m when saved. I see other files are around 16. What am i doing wrong? Any help is greatly appreciated.
    Mike
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: HP Elitebook 840 G2
    have you find the right bios chip?some laptops have two,one is connected to KBC and one to PCH
    • technog0d
      • Oct 2017
      • 6
      • usa
      There are two chips right next to each other. one is winbond and the other is some generic chip that doesn't seem to be able to be read...
      • technog0d
        • Oct 2017
        • 6
        • usa
        I have a new SOIC clip coming and a rework station. So, if the new SOIC clip doesn't work then i will remove the chips and try reading them that way. Additionally, i am going to try my raspberry pi and flashrom.
        • fester
          • May 2017
          • 158
          • Slovakia
          yes,not everytime you can read the content of the chip with soic clip,because of devices connected around the chip.I have tl866a programmer,with this clip can i read only some 1.8V chips on the board, others must go out..
          • technog0d
            • Oct 2017
            • 6
            • usa
            Okay... so i rad both chips now. BTW... the Pomona clip is the way to go. However, since reading that second chip when i go to turn on the laptop, it has a orange light that blings once every second in front. Additionally, the power button stays lit with no way to turn it off. Any thoughts?
            • fester
              • May 2017
              • 158
              • Slovakia
              wrong bios dump?
              • fester
                • May 2017
                • 158
                • Slovakia
                Had you cmos battery out while reading?
                • technog0d
                  • Oct 2017
                  • 6
                  • usa
                  cmos battery was out.
                  • Diesalweasel
                    • May 2016
                    • 49
                    • United Kingdom
                    Hi what is the chip number as I'm having problems reading mine on my 840 g2 the chip i have in mine is a 25q16dvsig
                    I own the tl866cs i also own the pomona clip and the 3m clip i either get aload of 0000 or a load of ffffff the voltage rating for mine is 2.7v to 3.6 volts .some of these chips you have to own the 1.8 volt spi flash adapter connected to the tl866cs. This is so I'm told I'm not experienced with bios chips maybe someone in here can helps us both out as mine as also got a password
                    • gitsfarmaz
                      Professnal tech
                      • Apr 2017
                      • 30
                      • Kenya
                      hallo all forum members...am having trouble with my 840 g2 bios which has password..tried the 820 g2 but delays for long before logo appears with machine not in committed state...have attached my two bios bin files...thanks in advance
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        here try this and reply.
                        • gitsfarmaz
                          Professnal tech
                          • Apr 2017
                          • 30
                          • Kenya
                          thanks for the quick reply but the power led only blinks but machine does not power on...is it possible to the ec bin file too( the 2mb ) one?...thanks in advance
                          • imranromi
                            • Jan 2015
                            • 1288
                            • Pakistan
                            You try again original bios is working or not reply me.
                            YOU SURE IS ORIGINAL BIOS 840 G2.
                            • gitsfarmaz
                              Professnal tech
                              • Apr 2017
                              • 30
                              • Kenya
                              thanks for the quick reply but the machine only blinks the power led continuously with no booting...kindly provide for the 2mb ec bin..thanks
                              • imranromi
                                • Jan 2015
                                • 1288
                                • Pakistan
                                i already say can you try original bios again why you need 2mb bios you say original bios password.the laptop model is 840 g2/820 g2?
                                • gitsfarmaz
                                  Professnal tech
                                  • Apr 2017
                                  • 30
                                  • Kenya
                                  the original bios works fine but if i reprogram with your edited 16 mb bios the bios password still remains..my machine is 840 g2..it is the original bios...tried the following bin files from this forum machine now has no password but takes too long before hp logo appears with the following message...''the embedded controller MUD data is not valid while MPM is locked. Please unlock MPM, and lock again to capture valid MUD data
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    the original bios works fine but if i reprogram with your edited 16 mb bios the bios password still remains..my machine is 840 g2..it is the original bios...tried the following bin files from this forum machine now has no password but takes too long before hp logo appears with the following message...''the embedded controller mud data is not valid while mpm is locked. Please unlock mpm, and lock again to capture valid mud data
                                    ok try this and reply.
                                    IF REMAINS PASSWORD SEND BOARD CODE.
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    If above not works try this.
                                    • gitsfarmaz
                                      Professnal tech
                                      • Apr 2017
                                      • 30
                                      • Kenya
                                      thanks so much the machine works perfectly now...i really appreciate
                                        HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 05:50 AM
                                        HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 05:20 AM
                                        HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
