HP Elitebook 840 G2
  • peste
    • 13600
    • ROMANIA
    #181
    Re: HP Elitebook 840 G2
    Originally posted by Paul.Junge2020
    Hello. Help is needed. There is HP 80 g2. I'm trying to remove the bios password through the programs - HPUnlocker, RCUnlocker_v_1_0.
    But I'm getting flashing white and red light.
    Help me please.
    Try..if it doesn't work, try the original bios again and see what happens..
    • Paul.Junge2020
      • Feb 2023
      • 39
      • Ukraine
      #182
      does not work. I did it with the original file - it doesn't work either ((( I don't know what happened
      • peste
        • 13600
        • ROMANIA
        #183
        well, what will happen!!!..you copied the original bios with errors...
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #184
          Exactly. The importance of the good verified backup is mentioned many times, including in the sticky and FAQ threads, it will be a lesson for him to carefully read all the sticky threads hereafter.
          Originally posted by piernov
          When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
          On Windows, you can use the command "fc /b" to check if two dumps are identical.
          Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
          Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
          Originally posted by SMDFlea
          Common SPI bios chip programming Questions and Answers
          Q: How do i know if i`ve made a good backup or not ?.
          A: One of the easiest ways is to make 2 backups,open both with a hex editor and use the
          File-Compare option.
          Scroll through and make sure there`s some code in the backups.If both files
          are all FF`s (empty) then you havn`t made a good backup or the chip is blank.Make multiple backups
          making sure all connections are good and all programmer settings are correct.Double check,triple check !
          Become a Badcaps supporter
          Thanks to all supporters.​
          • Paul.Junge2020
            • Feb 2023
            • 39
            • Ukraine
            #185
            I made 2 backup copies. Checked - they are identical.
            I don't know, maybe I'm doing something wrong...
            Can I find a replacement bios now?
            Laptop with discrete graphics card.
            hp 840 G2
            SN: BCAM2109CTF570LERW
            6070B0676404 REV 1.09 PDM:A02
            • Lover1abd
              • May 2023
              • 14
              Originally posted by wolf3d.exe
              My problem is solved. Issue was the lazy soldering job. Also I will attach the image that worked for me. After reprogramming chip log in to bios as a guest user, surprisingly create an admin account, login to that account and delete existing accounts. Also remove the password for the admin. Voila!
              Thanks for the original poster for the BIOS also I used Colibri as programmer. Thanks again for the poster of Colibri. It worked without any errors. I will attach that too.
              After using this bin laptop work fine ,
              But it's take around 20 seconds before hp logo comes up ,
              Please any idea how to fix it please
              This bin I used work but slow start up
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #187
                • Lover1abd
                  • May 2023
                  • 14
                  Originally posted by Vesko356
                  Works perfect, thanks
                  • Lover1abd
                    • May 2023
                    • 14
                    Hi
                    Need bin for hp 840 g2
                    25q128fvsq
                    Please
                    Unlock
                      • 21916
                      Hi
                      25q128fvsq
                      Please
                      Unlock
                      Please read the rules - https://www.badcaps.net/forum/showthread.php?t=103570
                      • shadow225
                        • Mar 2023
                        • 7
                        • cote d'ivoire
                        #191
                        hello!!!
                        can someone kindly unlock my hp840 g2
                          • 21916
                          Originally posted by shadow225
                          hello!!!
                          Havn`t you tried unlocking it yourself with RCUnlocker ? - https://www.badcaps.net/forum/showthread.php?t=103570
                          • shadow225
                            • Mar 2023
                            • 7
                            • cote d'ivoire
                            #193
                            i don't know how to
                            can you help me§
                              • 21916
                              i don't know how to
                              can you help me§
                              RCUnlocker https://www.badcaps.net/forum/showthread.php?t=98539
                              Usage: Drag and drop .bin file to .exe file.
                              • marcopollo63
                                • Sep 2023
                                Originally posted by technog0d
                                cmos battery was out.
                                What happens if you leave battery in?
                                Originally posted by fester
                                Had you cmos battery out while reading?
                                What happens if not taken out? Also does this apply to all laptops?
                                • wm86698
                                  • Oct 2020
                                  • 9
                                  • uae
                                  #196
                                  bro ineed 840 g2 tuch screen bios plz send me
                                • TECHO TN
                                  • Jan 2024
                                  • 68
                                  • algeria
                                  #197
                                  Hello everybody
                                  Hp elitebook 840 g2 turns off itself just after displaying the hp logo, in his MB there are two bios chips i tried to flash the main bios (16mo) many times with ezp2019 programmer but the problem is not solved.
                                  I think it will be solved by flashing the second bios chip ! ! (2mo) but i dont find the file can you help me please
                                  Serial number is joined in attachements
                                  originals Bios are joined too
                                    SMDFlea commented
                                    Editing a comment
                                    Thread merged with existing topic. You must type as text the laptop serial number,don`t post pictures please !
                                    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                    You MUST:
                                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                • TECHO TN
                                  • Jan 2024
                                  • 68
                                  • algeria
                                  #198
                                  Originally posted by TECHO TN
                                  Hello everybody
                                  Serial: 5CG6070SRR
                                  Model: A3009D510303
                                  • shamaltech
                                    • May 2023
                                    • 110
                                    • Sri Lanka
                                    #199
                                    Anybody fix this bios?
                                    Problem is laptop turning on but doesn't boot into windows.
                                    Stuck on Windows logo.
                                    Also cannot install any windows setup because when i boot from Windows bootable pendrive, it also stuck in Windows logo.
                                    Elitebook 840 G2
                                    S/N:5CG5250T25
                                    CT:PEVEC00WB8S4XR
                                    • shiyab
                                      • Sep 2023
                                      • 1608
                                      • india
                                      #200
                                      Elitebook 840 G2
                                      S/N:5CG5250T25
                                      CT:PEVEC00WB8S4XR
                                      HI try
                                        HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 05:50 AM
                                        HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 05:20 AM
