HP Elitebook 840 G2
  • shiriffsm
    Banned
    • Aug 2019
    • 35
    • 87116973284
    #41
    Re: HP Elitebook 840 G2
    please i need to remove bios password for elitebook 840 g2, this is my bios backup. thanks in advance
    • hamidtiaret
      • Sep 2019
      • netherland
      #42
      Originally posted by imranromi
      If above not works try this.
      hi sir how I can use this file to reset password
      thanks a lot.
      • f164
        • Sep 2019
        • 6
        • Algeria
        #43
        Re: HP Elitebook 840 G2: Flash BIOS to clean password
        hello, i have an hp elitebook 840 g2 bios password protected here is my file , i wrote a file downloaded from net but bios remained locked help please
        • peste
          • Dec 2016
          • 12806
          • ROMANIA
          #44
          try...
          • f164
            • Sep 2019
            • 6
            • Algeria
            #45
            Originally posted by peste
            try...
            hi thank you for the file i want just to ask if the bios is just in one chip or two ? because there is another chip with cFeon QH16-104HIP
            • RethoricalCheese
              • Mar 2013
              • 1518
              • Estonia
              #46
              password is stored in main bios chip. Only need to program one.
              • Nico Latour
                Banned
                • Sep 2019
                • 52
                • france
                #47
                dont change ec bin other a lot of trouble, the bins must be 16mb (send me bin and i unlock for you free)
                  • 20898
                  Password is in the main bios. Post your bios backup here .
                  • f164
                    • Sep 2019
                    • 6
                    • Algeria
                    #49
                    now guys i have a problem after writing the file uploaded by our friend peste , a black screen even after i wrote my backup file always the same problem, i noticed a strange problem in ch341a programmer when i make verify after writing the file i have an error message: chip memory with the contents are in disagreement , erase and blank check pass without problem, writing also except the verify operation, should i order a new chip or what to do help please?
                    my chip is W25Q128FV
                    SOFT VERSION 1.29
                    • f164
                      • Sep 2019
                      • 6
                      • Algeria
                      #50
                      Originally posted by smdflea
                      password is in the main bios. Post your bios backup here .
                      i already post it
                      • f164
                        • Sep 2019
                        • 6
                        • Algeria
                        #51
                        i already post it
                        • f164
                          • Sep 2019
                          • 6
                          • Algeria
                          #52
                          SOFT VERSION 1.29
                          the problem solved i mean the verify one but always black screen on laptop
                          • sifu26
                            • Nov 2019
                            • 5
                            Good morning, everyone. Thank you for accepting me into your forum. I too have a password to access the bios of my elitebook 840 with a 5th generation cpu i5. I called HP and they don't want to provide me with the SMC.bin file. As I can see in the message above, there seems to be a solution with the file "hp 840 g2 backup bios CLEAR PASSWORD.zip" but I don't know how to use it. I would like someone to explain to me how to do it, if possible. Thank you very much in advance.
                            • sifu26
                              • Nov 2019
                              • 5
                              I forgot to say it's an elitebook 840 G2.
                              • peste
                                • Dec 2016
                                • 12806
                                • ROMANIA
                                #55
                                Post your bios backup .
                                • sifu26
                                  • Nov 2019
                                  • 5
                                  I currently have version 1.05 of the bios but it makes the backup with the utility of version 1.30 (the latest version). I'll post the bios 1.30 backup if that helps. Thank you.
                                  • peste
                                    • Dec 2016
                                    • 12806
                                    • ROMANIA
                                    #57
                                    the one with the password .. it's not good
                                    • peste
                                      • Dec 2016
                                      • 12806
                                      • ROMANIA
                                      #58
                                      try this..
                                      • sifu26
                                        • Nov 2019
                                        • 5
                                        Thank you very much. But can you explain to me or give me an internet link to know how to install the.bin, or it's like if I would install the SMC.bin, I do the same thing with this.bin? Thank you.
                                        • peste
                                          • Dec 2016
                                          • 12806
                                          • ROMANIA
                                          #60
                                          desoldering the bios chip, put it in the programmer and rewrite it with what you need, it is important to make a copy of the original bios, but I think you did not already, find more information on the net.
                                            HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:50 AM
                                            HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 05:20 AM
                                            HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
