Need Bios HP 15-N203EX
  • dylen
    • May 2017
    • 174
    • Mauritius
    Hi, help please, need bios bin file for HP 15-203EX DAOU82MB6DO. rev D
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Need Bios HP 15-N203EX
    Look here
    https://www.badcaps.net/forum/showthread.php?t=48854
    • dylen
      • May 2017
      • 174
      • Mauritius
      Thanks, i have tried it, but no luck
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
