HP ProBook 6570b bios
  • almussafer
    • Jun 2019
    • 86
    • Iraq
    #41
    Originally posted by imranromi
    Re: HP ProBook 6570b bios
    Try this.
    Works great! Thanks, man
    • guester233
      • Jan 2025
      Originally posted by werinq
      Nothing worked... It just goes max fan as always and no display
      Just try to change the RAM, same thing happened to me
      • klutschi
        • Feb 2025
        • 7
        Good Morning,
        I need an unprotected biosfile.
        The protected is uploaded.
        Please help me.
        • peste
          • 13793
          • ROMANIA
          #44
          Originally posted by klutschi
          Good Morning,
          Please help me.
          post S/N, full name and model, motherboard model, product number,etc.
          • klutschi
            • Feb 2025
            • 7
            ProBook 6570b; Product A5E64AV; Serial 5CB328101Z; MB Serial RC8F32132FH1 H94V-0; Bios-Chip WINBOND W25Q64FV
            • peste
              • 13793
              • ROMANIA
              #46
              try..
              • klutschi
                • Feb 2025
                • 7
                Hi peste,
                thank you very much!
                • klutschi
                  • Feb 2025
                  • 7
                  The file did not work. I then edited the original file myself following the instructions from SIE-Tech. After programming, the notebook no longer starts and the LED next to the HDD LED flashes white at the front.
                  • peste
                    • 13793
                    • ROMANIA
                    #49
                    if you put the original content you extracted back on the chip and it doesn't work...what do you think happened??
                    • klutschi
                      • Feb 2025
                      • 7
                      I do not know. Is the chip defect?
                      • peste
                        • 13793
                        • ROMANIA
                        #51
                        I say that you first copied the chip with errors and posted it here.... The bios chip must be unsoldered from the board before writing or reading..
                        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                        solder wires between the programmer and the bios chip..​
                        • klutschi
                          • Feb 2025
                          • 7
                          Thank you. But soldering is not mine, because I have a tremor. So I will search someone, who can do it for me.
                          • nero_2025
                            • May 2025
                            #53
                            Hi!
                            I have the same issue. My HP 6570B starts without pressing any button, and the Caps Lock and Num Lock LEDs blink 3 times. The fan runs at maximum speed, but nothing appears on the display. I already tried writing different BIOS files, but the issue remains. I also read the BIOS with a chip programmerfrom a working laptop, saved it, and rewrote it, but the problem persists (the good laptop works fine). The RAM and CPU have both been tested and show no issues.
                            If someone has found the cause and can help me, please let me know.
                            Does this laptop have the Embedded Controller (EC) in the same BIOS chip? Both my BIOS chips are MXIC MX25L6406E, and the motherboards have the same revision.
                            Has anyone checked the VRAM?
                            • peste
                              • 13793
                              • ROMANIA
                              #54
                              Originally posted by nero_2025
                              Hi!
                              post the contents of the bios chip even if it is corrupted..
                              read the forum rules..
                              https://www.badcaps.net/forum/troubl...ore-posting​
                              • nero_2025
                                • May 2025
                                #55
                                This it is the Model , SN , BIOS CHIP , Unfortunattly i did not save the original BIOS bin file so i did not have it the original anymore
                                • peste
                                  • 13793
                                  • ROMANIA
                                  #56
                                  Don't post pictures unless asked..write with the keyboard..I said read the rules...
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • mkdj
                                    by mkdj
                                    Dear all,
                                    10-19-2025, 04:41 AM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • haitham sharabati
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    💀 Problem:😅
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
