Lenovo Thinkpad X1 Carbon 14282 Bios
  • JLCurve
    • Feb 2017
    • 32
    Hi I have a Thinkpad X1 Carbon 14282-2m that cycles on powerup. Fan and KB lights ramp up then down. I suspect it is a bios corruption problem. I have tried 16MB files for other similar boards (12xxx) but worst results (nothing comes on at all).
    If anyone has this file, I would be grateful.
    Thanks,
  • JLCurve
    • Feb 2017
    • 32
    Re: Lenovo Thinkpad X1 Carbon 14282 Bios
    Turns out there is a HW problem with the motherboard. So this bios image is probably a good one!
    Not much info on these Gen 4 X1 .
    Cheers!
    J.
    • Wahid Gul
      • Jun 2017
      • 5
      • Afganistan
      It has a password
      what is the password pleas
      • nemac98
        • Apr 2018
        • 18
        • Serbia
        I have same problem with same motherboard.Is anyone solved that problem?
        • RethoricalCheese
          • Mar 2013
          • 1518
          • Estonia
          2nd gen had problems with onboard memories. Not sure if 4th gen also has this problem. Similar symptoms.
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            Backup old bios... try and report
            • nemac98
              • Apr 2018
              • 18
              • Serbia
              i tried multiple bios and it always the same problem .. light up for just a second and turn off..laptop normally charges the battery...
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                Send serial number or if possible send me bios update link i try to make new bios then if bios problem i sure give display
                • nemac98
                  • Apr 2018
                  • 18
                  • Serbia
                  Here's the original bios .. but I'm slowly starting to believe that bios is not the problem
                  • Claudiomfa
                    • Nov 2015
                    • 455
                    • Portugal
                    Try this file, it was extracted from original website exe file and I repaired your file.
                    if not work then check hardware issues..
                    • foulou0238
                      • Mar 2014
                      • 109
                      • France
                      hello
                      i have this bios for Thinkpad Carbon X1 in my collection of bios if can help any one
                      • thala007
                        • May 2016
                        • india
                        bios is having password.
                        Let me know if anyone knows please
                        • gtiporter
                          • Apr 2020
                          • 5
                          • united kingdom
                          I have this motherboard on a lenovo x1 carbon yoga 20FR
                          I Think I bricked it after a bios update
                          It boots to bios but no further and cant repair in bios
                          i assume the bios is corrupt. The bios is here
                          https://englandandco-my.sharepoint.c...feHtQ?e=RgsB1Y
                          i have flashed the motherboard with a different bios but all it did was turn the fan on for 1 second and then die.
                          Is it possible to fix the original bios?
                          i have a ch341 to flash the motherboard. Otherwise I was looking to flash with the most recent bios update which is here
                          https://pcsupport.lenovo.com/gb/en/downloads/ds111756
                          but i dont know how to extract the bios or if it would work. I assume it was this bios that was updating when it bricked
                          If anyone can help I would be grateful.
                          • peste
                            • 12945
                            • ROMANIA
                            try...
                            • gtiporter
                              • Apr 2020
                              • 5
                              • united kingdom
                              Thanks.
                              I'll give this a go and come back
                              • gtiporter
                                • Apr 2020
                                • 5
                                • united kingdom
                                I'm now getting detection error on storage device(m.2)
                                but im thinking this might be a good sign.
                                I might have knackered the ssd from bios update but if the computer works with a replacement ssd then thats better than not working at all and now its looking at the ssd for i presume an operating system, means that maybe the bios is now ok?
                                ill work on this next and see what happens. Will let you know.
                                Thank you Peste - ive a got glimmer of hope here
                                • gtiporter
                                  • Apr 2020
                                  • 5
                                  • united kingdom
                                  MSD Flea -thanks for your suggestion (dont know if my email was sent to you)
                                  I got my computer to boot from an external drive running windows 10 which is great. so i may try:-
                                  - and flash to a newer bios as suggested by SMD Flea -which worries me now -its why im here in the first place but i guess i know how to recover it now.
                                  - otherwise see if the ssd can be recovered in some way (it doesnt show up in windows 10 which im running from the external hard drive)
                                  - or buy another one for about £33
                                  whatever happens i dont have a brick at the moment
                                  thanks for all your help. I would love to know what you did with the bios ie how to fix it myself in case i got in the same position again - i feel like i was helpless with that bit - or at least push me in the direction of a tutorial if there is one -or web page-but otherwise no problem
                                  thanks
                                    • 21150
                                    If its working fine now and you`re worried about flashing the bios again then leave it as-is .
                                    • gtiporter
                                      • Apr 2020
                                      • 5
                                      • united kingdom
                                      I can run this from an external drive now. Can't get it to recognise the m2 ssd even though it has the most up to date bios and IME.
                                      I know the m2 ssd works on another compter and i also tried a new m2 ssd with no luck. Ive reseated it and cleaned all the contacts etc. No luck
                                      My last thought was to remember this all happened not with a bios update but when the computer was updating the intel management. So might this be corrupt?
                                      SMDFlea -is the bios bin you gave me (which works) fixed because you cleaned the IME?
                                      If so then I guess I'm stuck and I will probably replace the motherboard as booting externally is a pain in the bum.
                                      Otherwise I might try and clean it although im not sure which firmware to use.
                                      If im now posting in the wrong place I apologise.
                                      Any help is always gratefully received
                                      • OVC2001
                                        • Sep 2019
                                        • México
                                        Lenovo Thinkpad X1 Carbon 14282-2M LRV1 Clear Me Please
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
