Lenovo Thinkpad X1 Carbon 14282 Bios
  • peste
    • 13904
    • ROMANIA
    Re: Lenovo Thinkpad X1 Carbon 14282 Bios
    try..
    • OVC2001
      • Sep 2019
      • México
      Lenovo Thinkpad X1 Carbon 4th Generation 14282-2M Locked
      • piszpunta
        • Jan 2019
        • 260
        • poland
        please remove password x1 carbon 4th 14282-2m
        I used LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
        working !!!!!
        • sarvarshoh
          • Feb 2022
          • Россия
          Originally posted by OVC2001
          Lenovo Thinkpad X1 Carbon 14282-2M LRV1 Clear Me Please
          they told you the password, if anything, can you also tell me what the password is??
          • sarvarshoh
            • Feb 2022
            • Россия
            Originally posted by Claudiomfa
            Backup old bios... try and report
            please tell me the password ?
              • 22241
              Read post #23 ,there is a tool to remove your password.You must remove the password from your own bios,don`t use any other.
              https://www.badcaps.net/forum/showthread.php?t=103526
              • jjj11x
                • Nov 2022
                The image attached worked for me after a failed BIOS update. I made the image from the one in post 20 using the instructions from here to "clean" the ME region.
                • jjj11x
                  • Nov 2022
                  I had previously tried an image from peste here, which mostly worked, except the laptop wouldn't recognize an M.2 NVMe SSD anymore (an old M.2 SATA SSD I had lying around was still recognized somehow).
                  • ipodnano16g
                    • Apr 2017
                    • 43
                    • VN
                    #29
                    Originally posted by peste
                    try...
                    file ok & ssd ok .
                    • f2295528
                      • Aug 2016
                      • Russia
                      #30
                      Working fine
                      • moshu
                        • Oct 2024
                        • 66
                        • Ireand
                        #31
                        Hi
                        I have a ThinkPad motherboard (14282 -2m LRV1 448.04P15.002M) which doesn't want to boot. Power light and fan does spin for several time then nothing. There is a bit of activity in the CPU cause is getting warm.
                        I assumed bios was corrupt and tried the bios images from here but none of them seems to work. Now power light 3 times and no fan of keyboard activity as previously.
                        Is there any other solution for this?
                        • peste
                          • 13904
                          • ROMANIA
                          #32
                          Originally posted by moshu
                          Hi
                          post the S/N, post the original content of the bios chip, the full name and model of the laptop,etc.
                          • moshu
                            • Oct 2024
                            • 66
                            • Ireand
                            #33
                            hi Peste,
                            I dont have those information. Original bios content was overridden.
                            Tested several bin files from here and managed to see the logo screen eventually, then the following errors: The LAN adapter NVM configuration is corrupted or has not been initialized then, in the next screen : "0183 Bad CRC of Security Settings in EFI variable"; and "2100 Detection error on Storage Device M2"
                            Then screen is stuck when I press F1 to get into Settings, where fan is spinning fast because CPU is hot, power light on
                            here is the bin that worked kind off
                            • peste
                              • 13904
                              • ROMANIA
                              #34
                              hi Peste,
                              The information is on the label on the case.
                              • moshu
                                • Oct 2024
                                • 66
                                • Ireand
                                #35
                                motherboard came as part of incomplete laptop parts, so not sure serial number I have on one of the bottom case belong to this.
                                TYPE 20FR-S1VROK
                                S/N R9-0LBJ8V
                                X1 Yoga 1st Generation
                                tried other bin fie and the "2100 Detection error on Storage Device M2" is not there
                                attached below, but still, nothing is happening after F1 (bios setup)
                                • moshu
                                  • Oct 2024
                                  • 66
                                  • Ireand
                                  #36
                                  with another bin file (uploaded below), managed to get into Setup for few seconds and I can confirm
                                  TYPE 20FR-S1VROK
                                  S/N R9-0LBJ8V​
                                  Unfortunately, getting into Setting is random or close to impossible.
                                  following errors appear: "0183 Bad CRC of Security Settings in EFI variable"; and "2100 Detection error on Storage Device M2"
                                  • kamkooltech
                                    kamkooltech
                                    • Jun 2019
                                    • 132
                                    • nigeria
                                    #37
                                    my lenovo x1 carbon has password.
                                    please help me auto patch my bios file or if any to use.
                                    i had tried to auto patch it, is not working for me.
                                    i think i'm not getting it right to auto patch it
                                    the serial number on the case is not more
                                    • chraa47
                                      • May 2016
                                      • 10
                                      • algeria
                                      #38
                                      remove password pls
                                        • 22241
                                        Originally posted by chraa47
                                        remove password pls
                                        Type the laptop serial number, full name and model, motherboard model, etc.
                                        read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                                        • chraa47
                                          • May 2016
                                          • 10
                                          • algeria
                                          #40
                                          remove password pls
                                          Lenovo Thinkpad X1 carbon 4 gen
                                          14282 2m lrv1 mb
                                          448.04p18.002m
                                          Serial is not clear 😭
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
