Hp15 au003tx bios needed
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    MODEL- HP 15 -AU003TX
    M/B CODE-DAG34AMB6DO REV D
    I need bios dump
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp15 au003tx bios needed
    No one has this dump???
    • smali
      • Sep 2014
      • 287
      • Pakistan
      check BIDxxx in your old dump one will be match in the attached folder
      • smali
        • Sep 2014
        • 287
        • Pakistan
        sorry for attachment....the file size was larger than allowed size so i split in to two folders..
        • smali
          • Sep 2014
          • 287
          • Pakistan
          the 2nd folder is here..
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Thanks smali. I'll try and revert back with results.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              My BID is 08209 and bios uploaded by you worked like a charm. Dmi info missing though whic i have taken care of. Thanks for your support Mr. Smali and entire badcaps community.
              • nasnus123
                • Jan 2016
                • 28
                • india
                How to find BID code if chip bad
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  No way
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
                  • James Maxwell
                    HP DM1-4000er Bios Dump needed
                    by James Maxwell
                    I badly need bios dump for HP DM1-4000er,
                    Model: HP DM1-4000er
                    Motherboard: DA0NM9MB6D0 REV.D
                    Product: QJ490EA#ACB
                    Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                    10-28-2024, 05:38 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • rednix01
                    Nuc7i5BNH Bios Dump Needed
                    by rednix01
                    I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
                    Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
                    I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...
                    06-19-2025, 06:37 PM
