hp pavilion g6 da0r33mb6f1 rev:1 bios
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    anyone got a bios dump for hp pavilion g6 The board code is da0r33mb6f1 rev:1 please
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    Re: hp pavilion g6 da0r33mb6f1 rev:1
    try this one.compare the bid with your dump.
    • Pascal Komlassan
      • Jan 2017
      • 809
      • TOGO
      thank's bro
      • toufik sat
        • Feb 2016
        • 136
        • los angles
        Re: hp pavilion g6 da0r33mb6f1 rev:1 bios
        thank's bro
        • toufik sat
          • Feb 2016
          • 136
          • los angles
          thank's bro
          • toufik sat
            • Feb 2016
            • 136
            • los angles
            thank's bro
            • Anas-SOS
              • Aug 2021
              • morocco
              thank you bro is working for my pavillion G6
              • olfelys
                HP Pavilion 500-560nf (Memphis-S, SSID 2B2C) – BIOS dump request (8 MB .bin)
                by olfelys
                Request: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
                My board enters jumper recovery mode but no BIOS files are available from HP anymore.
                I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
                Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
                post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...
                09-05-2025, 12:38 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                by haitham sharabati
                Hello engineers 😀,
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                💀 Problem:😅
                08-07-2025, 04:54 AM
