Help please ZRMAA - LA-A481P bios
  • Ahmed abdalla
    • Nov 2016
    • 5
    • Tanta
    Hi, I need this toshiba Bios file.
    ZRMAA - LA-A481P
  • Me.Orouji
    • Dec 2015
    • 117
    • Iran
    Re: Help please
    • gustarom
      • May 2013
      • 44
      • indonesia
      Re: Help please
      Originally posted by Me.Orouji
      thanks
      • sel3370
        • Aug 2017
        • 18
        • turkey
        Re: Help please ZRMAA - LA-A481P bios
        thanks
        • drhardware2022
          • Jan 2022
          • 15
          • Chincha
          ZRMAA - LA-A481P
          Thanks You Friend
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • HOHA
            BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
            by HOHA
            Hi can you help me
            I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
            IP3_TN16S_MB_V30_20210901A
            This is the old BIOS file, it is corrupted​...
            10-20-2024, 08:22 AM
