Nuvoton npce285paodx programming
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Does anyone know how to program Npce285paodx Kbc??
    I have svod programmer but i was not able to find any info on this chip programming. Is it programmable???
    There are articles suggesting Npce288/388 support for svod but no article found for npce285xxxx.
    I'm trying to do this on a dell cedar 13269-1 m/b
    Plese advice friends.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Nuvoton npce285paodx programming
    As per vinafix,no rom inside this kbc. So not programmable. Is it correct??
    • mielta
      • Apr 2015
      • 368
      Hi
      Yes it is not programmable
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Originally posted by mielta
        Hi
        Ok, Thanks for clarification
        • ravi_1617
          YY Solutions
          • Jan 2012
          • 348
          • India
          dell cedar 13269-1
          processor starts heating after connecting adapter ,3.3 & 5 volts present
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Originally posted by ravi_1617
            dell cedar 13269-1
            Very likely,cpu itself is bad
            • repairs
              • Nov 2013
              • 10
              • india
              how to remove dell cedar 13269 -1 Bios password
              after Reprogram now No power on any solution
              • couillu76
                yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
                by couillu76
                before you start the procedure read the bios eeprom and save it you might need it at the end
                1do not power on your svod yet
                2plug you ribbon 30x0.5 to the left of the keyboard connector
                3test pin with testeur if it beep go to next stage
                4 open svod software select 1.8v
                5 now plug your svod
                6 select nuvoton
                7 plug charger on the board/laptop
                8 press read id
                9 select 256k
                10 read nuvoton
                11 save reading, now unplug the svod
                12 open HxD software and open your 256k file the one you just saved
                13look...
                03-26-2023, 06:19 AM
              • vidargo87
                MEC 1633L Programming error with svod 3
                by vidargo87
                Hi I have a problem with stock Flash in MEC 1633L
                I connect to motherboard all pin and in SVOD 3 Recognise my MEC but:
                boot block in not protected mode
                i can´t erase erase and flashing this
                erase complete
                blank check : fail
                Lenovo x250
                09-11-2021, 02:15 PM
              • jonny0404
                how to program using svod 2 nuvoton NPCE388NB0DX
                by jonny0404
                hello guys i have a lenovo 520-14IKB CIUYA YB SA SD LA-E541P Rev 1.0 , it has a nuvoton ncpce388nb i know is programable, i been trying to program these nuvuton but it giving me problems i attach the svod i been using, can someone tell me the right way to program these kbc, with pins out please, all are ok i even have continuity from motherboard to svod, so i dont know what could be the problem....
                04-18-2020, 11:40 PM
              • araxnido
                Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                by araxnido
                Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                06-10-2025, 09:26 PM
              • zlr8r
                Advice on newer EC chip programming eg. MEC5107-LJ BGA
                by zlr8r
                Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                09-16-2025, 09:54 AM
