La-b162p
Every donation made will go towards server fees and maintenance costs.Comment
Re: La-b162p
Attached FilesComment
Re: La-b162p
Use NeoProgrammer software - https://www.badcaps.net/forum/showpo...50&postcount=5
Flash Ene kb9012 Sio Using Ch341A https://www.youtube.com/watch?v=GQGH6yZuXCc
Recommended to modify the ch341a voltage first if you have the black pcb version
CH341A volt mod https://www.youtube.com/watch?v=HwnzzF645hA
CH341A volt mod https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod
You can also buy pre-programmed chips from ebay and aliexpress.
If you want to buy an IO programmer there`s other models besides the one that @peste posted theres SVOD3, Vertyanov JIG, RT809F (with peb1 adapter board,but limited to only kb90xx) ,RT809H with adapter board.
.Last edited by SMDFlea; 10-15-2021, 09:42 AM.Comment
Re: La-b162p
post the original bios of the laptop so corrupt.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by ngngocson113hi everyone
i need bios asus tp301uj ( "uma " vga share)
my mainboard doesn't use vga chip and it uses vga together with cpu.
I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
thanks everyone....-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
