da0sp9mb8d0 BIOS
  • quic307
    • Jun 2015
    • 255
    • Greece
    da0sp9mb8d0 BIOS
    I have the HP envy 17-2000 and I need bios.
    da0sp9mb8d0 rev D.
    I attached the old and from HP the new (0159B) which I cant decode it....
    If someone can help me ... ?
    Thanks ...
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: da0sp9mb8d0 BIOS
    try this
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Sorry the earlier file was uploaded by mistake. Dont use that file.
      Try this file.Should work
      • quic307
        • Jun 2015
        • 255
        • Greece
        It works, thank you bro.
        I attached working +ec ... if someone needs ...
        • Anselme
          • Jul 2016
          • 21
          • Ghana
          Great thought
          • quic307
            • Jun 2015
            • 255
            • Greece
            Hello, the laptop turns on and works, but after few secs shutdown and no power after that.
            If I try to reflash bios, same issue.
            Maybe ec its not so good...
            Does anyone has good EC!!! to check?
            • mdsajib
              • Aug 2017
              • Bangladesh
              x551ma
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • joshAU
                BIOS file for N550JK (original dump attached)
                by joshAU
                Hi all.
                I'm looking for a BIOS file for an Asus N550JK.
                I have a Asus R552J, which I believe is identical to the Asus N550JK.
                I downloaded the latest BIOS (210) for the R552.
                It is named N550JKAS.210.
                The BIOS file is however only 6mb in size.
                I've read the chip with a CH341A programmer and verified the file.
                That file is actually 8mb in size.
                I'm wanting to remove the BIOS password from this unit.
                It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                08-09-2022, 08:06 PM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
              • maanee11
                Help to get Lenovo BIOS bin file for Thinkpad T560
                by maanee11
                Hello Everyone,
                I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                05-15-2022, 11:59 AM
