Acer R3 Bios
  • dspok
    • Jan 2014
    • 554
    • Nepal
    Acer R3 Bios
    Somebody plz share bios dump for Aspire R3-471TG.
    DA0ZQXMB8E0 REV E
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Acer R3 Bios
    Post your backup, maybe someone can help you.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      Re: Acer R3 Bios
      having backup of both chips would help... i could extract it from acer suport site but i need example to know where to cut
      Im Back... sort of...
      • techman1025
        • Jun 2014
        • 497
        Re: Acer R3 Bios
        Here
        Techman1025
        • Guy_With_Pants
          • May 2017
          Re: Acer R3 Bios
          go to the acer website and check there got mine form there
          https://www.acer.com/ac/en/US/content/drivers
          • dspok
            • Jan 2014
            • 554
            • Nepal
            Re: Acer R3 Bios
            Actually there was no bios chip, removed by somebody. Bios from Acer support is encrypted. I will test attached BIOS will inform if it works.
            Thanks everybody.
            • dspok
              • Jan 2014
              • 554
              • Nepal
              Re: Acer R3 Bios
              Sorry to say techman, attached dump didn't work.
              • techman1025
                • Jun 2014
                • 497
                Re: Acer R3 Bios
                Hi
                Ok confirm want was tested ? First whats your problem with computer ? whats it doing with old dump and new dump. Did you test RSMRST 3.3v & S5 3.3 VOLTS is it present ? secondary voltage present external keyboard or mouse lighting up or if you press caps lock does it light or even external mouse either or . Let confirm for sure it's a bios problem if it is i will help you fix it.
                techman1025
                • dspok
                  • Jan 2014
                  • 554
                  • Nepal
                  Re: Acer R3 Bios
                  @techman1025
                  Every voltages are good but no display. Capslock won't light up.
                  RAM ok, led panel ok, lvds cable ok.
                  FYI, it's a discrete version with touch.
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    Re: Acer R3 Bios
                    @techman1025
                    I have look the bios was you upload, there is something wrong I guess, ME region was missing. Please take a look again.
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      Re: Acer R3 Bios
                      lets stay simple here
                      on acer website there is no full bios update only partial, no me region or descriptor
                      in ver 1.09 it looks like there is ec update also, lots of region and lots of work to reconstruct bios
                      anyways if someone have account pls download and attach here
                      http://**************/dump/kompjuter.../426-1-0-39949
                      • meritosari
                        • Oct 2010
                        • 774
                        • Indonesia
                        Re: Acer R3 Bios
                        if I share it from remont, will banned forever. already download from s***forum. Let you to rebuild again.
                        check PM please, already send link the dump from s***forum.
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          Re: Acer R3 Bios
                          try this
                          https://drive.google.com/file/d/0B1t...ew?usp=sharing
                          • dspok
                            • Jan 2014
                            • 554
                            • Nepal
                            Re: Acer R3 Bios
                            Thanks again.
                            I'm confused about file size of 26mb ala_borbe?
                            • ala_borbe
                              aka Donald
                              • 1625
                              • Malta
                              Re: Acer R3 Bios
                              2 bios 16bm each
                              try one, if does not work, try other
                              • dspok
                                • Jan 2014
                                • 554
                                • Nepal
                                Re: Acer R3 Bios
                                But I have 8mb chip only.
                                I can see me ver 10.0.30.1072 is 5MB, can you compile with 1.5 one.
                                • ala_borbe
                                  aka Donald
                                  • 1625
                                  • Malta
                                  Re: Acer R3 Bios
                                  i could try but only if you confirm working or not
                                  • dspok
                                    • Jan 2014
                                    • 554
                                    • Nepal
                                    Re: Acer R3 Bios
                                    @ala_borbe
                                    I expect your upload is good but I'm sorry I can't test becoz I don't have such bios chip.
                                    • ala_borbe
                                      aka Donald
                                      • 1625
                                      • Malta
                                      Re: Acer R3 Bios
                                      thay are not expensive
                                      http://www.ebay.com/sch/i.html?_from...25q128&_sop=15
                                      also i dont know will it work, it need to be tested
                                      strange bios on this mobo
                                      • meritosari
                                        • Oct 2010
                                        • 774
                                        • Indonesia
                                        Re: Acer R3 Bios
                                        Try this from vietnam site:
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                        • Wg188
                                          ACER Veriton Z4660G AIO bios help
                                          by Wg188
                                          I have an Acer veriton Z4660G all in one pc,
                                          Model: Z4660G-I5850H1 (VZ4660G_W)
                                          Need bios dump and schematic would save my life !
                                          to make a long story short I bought this all in one used
                                          with a broken lcd, with the objective of making a custom desktop out of it
                                          ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                          06-17-2023, 02:20 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • James194zt
                                          Acer Nitro 50-640E Corrupted BIOS Dump
                                          by James194zt
                                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                          04-28-2025, 03:29 PM
                                        • codeace110
                                          🚨 Need Help Reviving an Acer X4690G After Failed BIOS Update
                                          by codeace110
                                          Hey guys,
                                          I tried updating the BIOS on my Acer X4690G, but the power got interrupted mid-update, and now the BIOS is corrupted. The system won’t boot properly anymore.
                                          Has anyone dealt with this kind of failed flash before? Any tips on how I can recover or fix the BIOS?
                                          I already searched everywhere for a BIOS dump specific to the X4690G, but I couldn’t find any. If anyone has a working dump, a backup, or knows where I can get one, please let me know.
                                          Here’s a dump of my corrupted BIOS, and I’ve also included the .CAP BIOS file I downloaded...
                                          Yesterday, 12:09 AM
