Acer R3 Bios
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Acer R3 Bios
    Originally posted by ala_borbe
    thay are not expensive
    http://www.ebay.com/sch/i.html?_from...25q128&_sop=15
    also i dont know will it work, it need to be tested
    strange bios on this mobo
    Originally posted by dspok
    Thanks again.
    I'm confused about file size of 26mb ala_borbe?
    Yup..a bit make me confuse too. From remont only 8mb, but from s***forum have 16mb.
    I rebuild again Intel and ME region taken from remont, the rest from official update 1.09. Hope it's work if you want to try it. Rebuild only 8mb following file from remont.
    Have reading schematic, U24 W25Q64FVSSIQ -- 8MB. Is there a possibility the schematic to cheat us?
    • dspok
      • Jan 2014
      • 554
      • Nepal
      Re: Acer R3 Bios
      @meritosari
      Attached bios v1.09 worked, thanks a lot.��������
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        Re: Acer R3 Bios
        @meritosari
        respect in skill and a way of thinking
        what did you use to recompile with smal me... fitc?
        Im Back... sort of...
        • dspok
          • Jan 2014
          • 554
          • Nepal
          Re: Acer R3 Bios
          @ala_borbe
          I already tried with fitc but it doesn't compile 8mb instead compiles 3 files two 8mb and one 16mb. Both 8mb files doesn't include me and bios region.
          • dspok
            • Jan 2014
            • 554
            • Nepal
            Re: Acer R3 Bios
            By the way meritosari how did you extract bios region from Acer support, I see that was encrypted.
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              #26
              Re: Acer R3 Bios
              @meritosari
              I think that I was wrong to choose word "rebuild", should be word "mix or fix". I belive that You're best than me about that, I knew it. . Since I gave you wrong the dump as reference.
              The tools that was require has been being on this forum, but I won't mention it. Several thread was mention it. ( I known maybe only clue, like a puzzle you should find it your self ). The key is you should have original backup even it's not working bios.
              The only one thing what I'm think now is if using bios from another laptop, then there are two kind laptop with same unique ID....That's why HP need fix DMI to avoid double Unique ID. Also other reason is SN windows original store on chip.
              • Mr.dialogue
                • Sep 2015
                • 13
                • pakistan
                #27
                Re: Acer R3 Bios
                Thanks alot work done ok display tested
                • Mr.dialogue
                  • Sep 2015
                  • 13
                  • pakistan
                  #28
                  Re: Acer R3 Bios
                  Ok tested thanks all
                  • Pascal Komlassan
                    • Jan 2017
                    • 808
                    • TOGO
                    #29
                    Re: Acer R3 Bios
                    Originally posted by techman1025
                    Here
                    Techman1025
                    hello please somebody help me to remove password in this bios
                    • Pascal Komlassan
                      • Jan 2017
                      • 808
                      • TOGO
                      #30
                      Re: Acer R3 Bios
                      any help
                        • 22312
                        Re: Acer R3 Bios
                        Originally posted by Pascal Komlassan
                        any help
                        Yes, you have to be patient. If it doesnt work go to bios-pw.org .
                        24A000 - 24A030 W
                        240000 - 2400FF D
                        • Pascal Komlassan
                          • Jan 2017
                          • 808
                          • TOGO
                          #32
                          Re: Acer R3 Bios
                          Okay thanks bro
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            #33
                            Re: Acer R3 Bios
                            try this.... i test some new method to remove password from original bios
                            • addaphp
                              • Dec 2017
                              • ไทย
                              #34
                              Re: Acer R3 Bios
                              @meritosari
                              • ravenmx
                                • May 2018
                                • 184
                                • puebla
                                #35
                                Re: Acer R3 Bios
                                thanks you this work forme
                                • zurvanielle
                                  • Feb 2017
                                  • 137
                                  • Philippines
                                  #36
                                  Re: Acer R3 Bios
                                  TNX @ala_borbe.... it works....^_~
                                  • neopozi
                                    • Nov 2013
                                    • 8
                                    • Malaysia
                                    #37
                                    Re: Acer R3 Bios
                                    Salam kenal, Pak Meri
                                    After so many bioses i've tried, this v1.09 works for me!
                                    Thanks. Terima ksih , pak.
                                    • iaf86
                                      • Mar 2017
                                      • 39
                                      Re: Acer R3 Bios
                                      Hi could you please upload the 1.09 file again Because this package is corrupted some how.
                                      • peste
                                        • 13931
                                        • ROMANIA
                                        #39
                                        Re: Acer R3 Bios
                                        nothing corrupt ... update winrar or use 7zip ..
                                        • mail2gen.next
                                          • Nov 2012
                                          • 7
                                          • India
                                          #40
                                          Re: Acer R3 Bios
                                          v1.09 didnt work for me.
                                          My laptop is touchscreen with graphics.
                                          Posting old original bios. Please help.
                                          • EbrahimSiami
                                            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                            by EbrahimSiami
                                            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                            **What I have tried so far:**
                                            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                            07-02-2025, 02:31 PM
                                          • Wg188
                                            ACER Veriton Z4660G AIO bios help
                                            by Wg188
                                            I have an Acer veriton Z4660G all in one pc,
                                            Model: Z4660G-I5850H1 (VZ4660G_W)
                                            Need bios dump and schematic would save my life !
                                            to make a long story short I bought this all in one used
                                            with a broken lcd, with the objective of making a custom desktop out of it
                                            ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                            06-17-2023, 02:20 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • James194zt
                                            Acer Nitro 50-640E Corrupted BIOS Dump
                                            by James194zt
                                            My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                            All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                            04-28-2025, 03:29 PM
                                          • codeace110
                                            🚨 Need Help Reviving an Acer X4690G After Failed BIOS Update
                                            by codeace110
                                            Hey guys,
                                            I tried updating the BIOS on my Acer X4690G, but the power got interrupted mid-update, and now the BIOS is corrupted. The system won’t boot properly anymore.
                                            Has anyone dealt with this kind of failed flash before? Any tips on how I can recover or fix the BIOS?
                                            I already searched everywhere for a BIOS dump specific to the X4690G, but I couldn’t find any. If anyone has a working dump, a backup, or knows where I can get one, please let me know.
                                            Here’s a dump of my corrupted BIOS, and I’ve also included the .CAP BIOS file I downloaded...
                                            Yesterday, 12:09 AM
