toshiba L755D- s5241 need bios file
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello every one.
    could i ask for bios bin for this model thanks.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    Re: toshiba L755D- s5241 need bios file
    anyone pls
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • HOHA
      BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
      by HOHA
      Hi can you help me
      I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
      IP3_TN16S_MB_V30_20210901A
      This is the old BIOS file, it is corrupted​...
      10-20-2024, 08:22 AM
