Cannot read cFeon QH64-104HIP bios chip
  • wall
    • Apr 2016
    • 37
    • Portugal
    Hi, I tried to read my laptop's bios chip with a CH341a but there is nothing similar to QH64 to choose from the software's list, only 25Q64 but that didn't work and the auto-detect couldn't identify the chip either.
    What could be the problem?
    • 31270
    Re: Cannot read cFeon QH64-104HIP bios chip
    post a datasheet for it
    • wall
      • Apr 2016
      • 37
      • Portugal
      Datasheet
      User @exetico was able to read it, his auto-detect said EON EN25Q64 (thread).
      • wall
        • Apr 2016
        • 37
        • Portugal
        I think my programmer is not working correctly, I tried it on two other chips and it can't identify them, and reads only FF or 00 but Windows recognizes it and I hear the new device connected sound when I put the clip on the chip.
        This is my second CH341a that stopped working.
        Does anyone recommend getting an EZP2010/13 over another CH341a?
          • 31270
          you should fit the chip in the programmer before you connect it to the usb
          • wall
            • Apr 2016
            • 37
            • Portugal
            I tried every combination, I think this programmer is dead.
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              try other to chip know working to confirm programmer is working or dead
              what version of sofrware do you use?
              Im Back... sort of...
              • wall
                • Apr 2016
                • 37
                • Portugal
                To make sure the problem isn't the SOIC8 clip I desoldered a W25Q64FVSIG from an old tablet and soldered it directly to the adapter that came with the programmer, it still couldn't identify it or write anything, it was already empty.
                Then I saw a 25P05AV on an old IDE hard drive and to make sure the problem isn't the 1.8v adapter I tried that too and it still couldn't identify or read it, reads always 00 00 00 00.
                • Awejire
                  • Mar 2022
                  • 24
                  • Nigeria
                  Same thing happened to my own ch341a programmer, it went dead after the first use
                  • Verlengsnoer
                    • Sep 2016
                    • 110
                    • Netherlands
                    i have ch341a and ezp2019+
                    but u need to solder a wire on pin 4 and gnd on the ezp, or it does not or less chips,
                    even the database of supported chips on the ezp software is bad,
                    so yeah the ch341a is way better with chip support
                    • just_bios
                      • Mar 2021
                      • 43
                      • Netherland
                      hey guys..
                      is anyone readed this ic (cFeon qh64a-104) with CH341A..? or which tool is supported..?
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        Originally posted by just_bios
                        hey guys..
                        TL866II
                        • henr
                          • Oct 2023
                          • indonesia
                          hey guys..
                          Worked fine with ch341b , erasing, blank , wriye, verify.
                          neo programmer, ch341 programmer worked no issue..my chip is without the H ..cfeon Q64-104hip, auto detect also worked perfectly.
                          My initial issue was that it wasn't soldered properly to the sop8 to dip8 board so not making good contacts. Re soldered the legs and beep every legs with multimeter
