Dell E5530 bios chip issue
  • mikkele86
    • Apr 2017
    • 78
    • Danmark
    Hello.
    I have a few Dell E5530 laptops and the bios is locked with a admin password.
    So I decided to re-program the bios chip, U52 and U53.
    At first, it looks like it worked, but every time I entered bios and saved my settings followed by a restart, it did'nt want boot properly. it's stuck at black screen, but LED is ON and CPU is running.
    By further investigations I discovered, I had to CLEAR CMOS after every reset before it would boot normally again, all settings lost ofc.
    I have 1 possible solution I want to try, boot into windows and reflash bios with a new one but that's going to complicated if I have to clear CMOS every time....
    Does anyone have knowledge what is causing this issue ?
    Dell E5530
    Motherboard info:
    Hannstar QXW10 LA-7902P
    Rev: 1.0 (A00)
    2012-03-05
    bios chip : Winbond W25Q64FV & W25Q32BV
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Re: Dell E5530 bios chip issue
    This problem happend before Dell Bios Logo or after
    • mikkele86
      • Apr 2017
      • 78
      • Danmark
      before.
      I push start button, lights gets ON and nothing, black screen.
      • mikkele86
        • Apr 2017
        • 78
        • Danmark
        solved it.
        I was using my TV with HDMI as and Dell E5530 does not use HDMI output in older bios's.
        Pluggin in the native LCD, i got image on screen.
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
          by SMDFlea
          Bad...
          09-02-2021, 04:40 PM
        • JoWed
          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
          by JoWed
          Hello Community,
          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
          07-01-2025, 09:32 AM
        • ed1i
          Dell Inspion 7610 bios chip
          by ed1i
          Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
          01-16-2025, 02:14 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
