Need K55VM REV 2.0 bios
  • TheQuentincc
    • Mar 2017
    • 64
    • France
    Hi, I have a K55VM board that display nothing at boot, I changed the GPU (which is now a GT635m 2Gb GDDR5), now I'm sure that the bios is corrupt so I need to found a new one to replace it, but my board is originally mounted with a GT630M (not working anymore) and I replaced it for a GT635M from K55VM REV 2.2 motherboard (not working anymore).
    So can I flash rev2.2 bios into rev2.0? If I flash 2.0 bios did the GT635M will work?
    I only found 2.2 bios in the forum but no 2.0, that's why I ask.
    The last question : Did is worth to change the eeprom? I heard that my winbond 25Q64FVIG can be corrupted easily ?
    Thanks for all
  • konesava
    • Mar 2014
    • 10
    • austria
    Re: Need K55VM REV 2.0 bios
    I can help you only with you last question,if you are using TL866 just check quad enable(config) and it won't get corrupted.
    • TheQuentincc
      • Mar 2017
      • 64
      • France
      I don't have any reprog tool, I just wanted to find bios to flash and ask to a professionnal to do it (and pay)
      • cacla
        • Apr 2015
        • 444
        This dump is for ASUS K55VM
        • TheQuentincc
          • Mar 2017
          • 64
          • France
          A dump for rev 2.0 or 2.2?
          • cacla
            • Apr 2015
            • 444
            Sent me sn form you model and i will find you dump. This dump is by model, not by rev.
            One moment you change GPU card right?
            • TheQuentincc
              • Mar 2017
              • 64
              • France
              I don't have the right sn number for my motherboard (I only know that it came with A55V series), and It's not the stock GPU, I tought the stock GPU is GT630M and I have GT635M.
              So I tried to swap bios from rev 2.2 to 2.0 and it work but it seems to crash very quickly or just not boot at all (maybe ram problem)
              • qonma
                Kuli Solder
                • Jun 2017
                • 185
                • INDONESIA
                Solved???
                • malangg
                  • Sep 2014
                  • 34
                  • United Kingdom
                  here is dump. k55vm rev2.0
                  • lolipopguildie
                    • Jul 2018
                    • 4
                    • Antarctica
                    May I please know how to use these bios dumps? how do you flash it?
                    • TheQuentincc
                      • Mar 2017
                      • 64
                      • France
                      Hi, I didn't flash the bios myself because the laptop was bricked so I ask someone to flash me a new eeprom and I desolder/resolder the new eeprom on the motherboard.
                      Bad luck for me it didn't work well, it was a bad power that cause the computer not to boot (I don't remember the reference but it was not so far from the main 19.5V on the circuit)
                      • lolipopguildie
                        • Jul 2018
                        • 4
                        • Antarctica
                        @TheQuentincc Ah i see, Im currently having issues with my new K55VM board with a GT630m. Unfortunately the new board have a K55VJ bios instead of K55VM. Im guessing its because of the bios difference that GT630m isn't working. bios is probably expecting a GT635m. Im researching on how to flash K55VM bios onto the new board.
                        • dqtech
                          Badcaps
                          • Jul 2018
                          • 639
                          • N/A
                          bios work...thanks a lot
                          • mrtlty363
                            • Feb 2019
                            • 5
                            • türkiye
                            cacla thank brooo
                            • Vanara computers
                              • Sep 2020
                              • 5
                              • India
                              its working tq
                              • Vikas05viki
                                • Mar 2017
                                • 12
                                • India
                                thankssssss sir it's working perfectly.
                                • kukasIII
                                  • Aug 2012
                                  • 11
                                  • lisboa
                                  hi to all, just say thanks for the dumps.. another win sucess (used malangg​, file)
                                  • ecourse Easy
                                    • Jun 2024
                                    • indonesia
                                    need bios asus a55v firmware k55vm rev 2.0
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12336
                                      Rule
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • abhorsen
                                        Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                        by abhorsen
                                        Hey guys,
                                        Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                        Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                        Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                        07-06-2023, 10:22 AM
                                      • mrrubik
                                        Dell Optiplex 7010 micro bad BIOS flash?
                                        by mrrubik
                                        Hi folks,
                                        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                        Steps I took:
                                        1. Read BIOS with CH341a, verified hash twice
                                        2. Patched
                                        12-23-2024, 04:11 PM
                                      • AkaBukai
                                        Is it okay to flash stock bios onto the motherboard's BIOS?
                                        by AkaBukai
                                        Hi there,
                                        I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                                        The little LED on the power button is flashing slowly and nothing happen.
                                        This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                                        So I decided to flash the BIOS using a cheap programmer.
                                        And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                                        I also...
                                        12-19-2024, 12:15 PM
                                      • spmetroil
                                        Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                                        by spmetroil
                                        I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                                        The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                                        I have a CH341A programmer and I already attempted the following steps:
                                        1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                                        2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                                        3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                                        08-19-2025, 09:23 AM
