hp probook 440 g3 bios
  • unlockdev
    • 81
    could any one help with 440 g3 bios dax61cmb6c0 rev c
    Thank you
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp probook 440 g3 bios
    Backup and Try this
    • qsenc
      • 40
      try this..it worked for my 430 g3
      • unlockdev
        • 81
        my laptop is rev c not rev G
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Give it a try.Very likely it will work
          • abdulmuti622
            • Apr 2017
            • 7
            • Ranie
            please send me bios hp probook 440 g3
            mb version DA0X61MB6G0 REV : G
            • maybel
              • Dec 2017
              • 24
              • philippines
              any body can help me.. BIOS hp probook 440 g3
              DAOX61MB6G0 REV:G MODEL:X61
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3599
                • slovakia
                i need this bios too
                  • 21006
                  Try this one .
                  • peste
                    • Dec 2016
                    • 12868
                    • ROMANIA
                    look one from me ...
                    • Assembler
                      • Dec 2017
                      • 8
                      • Italy
                      Hi friends, i have this laptop ( rev G ) i see on youtube that for 2 long beep and 2 short beeps it's necessary to reflash the BIOS eprom.
                      the eprom name is Winbond 25q128fvsq
                      i have 2 programmer CH341 (GOLD type) .. and a new TL866II PLUS...
                      i think thatthe TL866II PLUS is the better to flash the image, but i tried with all these roms (maybe i ve no tried the CLEAN version) , everything seems ok but the laptop just start, the fan is spinning (increasing speed) but there are no beeps.
                      i'm not whure if i'm selecting the correct flashing procedure, beacuse i have 2 choices:
                      Winbond 25q128fv
                      Winbond 25q128fv (OTP)
                      (these 2 with soic8 or soic16... and i think soic8 is the right choice)
                      bat what i need to select? i used always the 1st choice (NOT OTP)
                      if i select the OTP i have more choices when loading the dump...
                      for example: "to region" that can be: Default, FLASH, OTP secu.R
                      or .. "file format" that i think it's correct with: BINARY (and not intel HEX)
                      anyone can help me to be sure that i was programming the eprom correctly before starting searching something else on logic board.
                      thank you! and merry christmas
                      • peste
                        • Dec 2016
                        • 12868
                        • ROMANIA
                        find tutorials on the net, for any of the programmers.
                        https://www.google.ro/search?source=...j0.OLCCjcAMT9E
                        • Assembler
                          • Dec 2017
                          • 8
                          • Italy
                          Hi Peste, i have the manual and i readed/programmed also some Asrock/Asus bios chips with success... the only thing i can't understand is if these dumps (posted here) needs the (OTP) selection (on eprom type) ... just asking if someone that own this programmer can explain how to re-flash these dumps, just to be sure that i'm doing everyhting in the right mode.
                          • peste
                            • Dec 2016
                            • 12868
                            • ROMANIA
                            if the bios chip model is not exactly in the programmer's database, you can also use OTP ...
                              • 21006
                              OTP is one time programmable, best not to use it .
                              • laptopbn
                                • Jul 2016
                                • 71
                                • Viet Nam
                                my laptop is rev c need this bios too
                                • peste
                                  • Dec 2016
                                  • 12868
                                  • ROMANIA
                                  try...
                                  https://www.alisaler.com/hp-probook-...6c0-revc-bios/
                                  if it doesn't work, post your original bios here.
                                  • piszpunta
                                    • Jan 2019
                                    • 249
                                    • poland
                                    My hp proobok 440 g3 motherboard DAX61CMB6C0 REV C
                                    when I connecting AC only the LED on the switch is on.
                                    the screen is black.
                                    the fan not turning.
                                    my backup bios here:
                                    any suggestions?
                                    • Madhusha
                                      • Apr 2012
                                      • 15
                                      • Srilanka
                                      430_440_G3 N78_0138 ME_CLEAN.zip (5.57 MB
                                      working!!!
                                      • olo
                                        • Jul 2012
                                        • 11
                                        • ua
                                        Originally posted by SMDFlea
                                        Try this one .
                                        File 430_440_G3 N78_0138 ME_CLEAN.zip (5.57 MB)
                                        Work!!! Thank you!!!
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
