hi how unlock macbook pro
Re: how unlock macbook pro
There this also bruteforcing with a Teensy or other like reprogramer chips. I'm currently trying it on a Macbook Pro that requires 6 pins.
Here's the Github for the script:
https://github.com/orvtech/efi-bruteforceComment
by bouchhi
i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
I need help or information?
Does anyone have the minat2 activator 1.4 software?
Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
Thank yo...-
Channel: BIOS Requests ONLY!
03-12-2025, 10:14 AM -
by keats11I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM -
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by SMDFleaCopying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....-
- Loading...
