hp 840g2 bios unlock help
  • qsenc
    • Dec 2010
    • 45
    I need to unlock bios for hp 840g2
    Thanks in advance for help !!
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: hp 840g2 bios unlock help
    try this
    1. 1st file only for your notebook, related with your ec bios and your dmi.
    2. if 1st file not working use 2nd files (main+EC), but you must flash your main and ec... and your dmi will different with your chasis..
    goodluck
    • qsenc
      • Dec 2010
      • 45
      Originally posted by rioreno
      try this
      goodluck
      first i flashed the main with first file, system ask for administrator pasword and a domain
      seccond i flashed the main + ec with second files but is the same
      i also send you an PM...thank you
      • staicugabi
        • Feb 2017
        • 11
        Is this issue resolved? I face the same situation.
        Thank you!
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
