Toshiba C55-A DB10BM how read/change Windows Key from damaged dump BIOS
  • awato
    • Jan 2017
    • Poland
    Hi there
    Is anyone has idea how to read and change Windows 8 key. I have read windows key from damaged dump bios, and change it in working dump.
    Key is not visible in hex editor.
    Motherboard type is: DB10BM-6050A2623101-MB-A02
    and IC is: 25Q64FWSIG
    Is anyone has any idea?
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • haitham sharabati
    by haitham sharabati
    Hello engineers 😀,
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    💀 Problem:😅
    08-07-2025, 04:54 AM
  • DProf.
    TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
    by DProf.
    High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
    Toshiba Dynabook T55/AB, PT55ABP-BJA2
    MODEL NAME. Satellite L50-D series
    P[ART NO PS57MN-00600R
    Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
    09-26-2024, 04:30 AM
