Toshiba C70-C-1G7 AR10SU/CU MB R2.1 bios
  • dkza
    • Aug 2016
    • 8
    • Poland
    Hello.
    I need bios dump for Toshiba C70-C-1G7
    PSCSEE-04J014DU
    AR10SU/CU MB R2.1
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: Toshiba C70-C-1G7 AR10SU/CU MB R2.1
    Originally posted by dkza
    Hello.
    PSCSEE-04J014DU
    AR10SU/CU MB R2.1
    try this...
    • dkza
      • Aug 2016
      • 8
      • Poland
      on the BIOS laptop gets 0,2A and nothing more happens.
      • YOUN
        • Feb 2015
        • 89
        • Burkina faso
        Help me to fixed my bad bios ar10su/cu r2.1
        • fsc2003
          • Mar 2015
          • 31
          • turkey
          hello I test your bios on my c70-c-123 psc8je and your bios is working
          so your problem is not on bios
          • YOUN
            • Feb 2015
            • 89
            • Burkina faso
            Thank
            • kalisko
              • May 2016
              • 45
              • Serbia
              Hello.
              PSCSEE-04J014DU
              AR10SU/CU MB R2.1
              100% good
              just downloaded from the programmer
              • zigana
                • Aug 2013
                • 41
                • turkiye
                Re: Toshiba C70-C-1G7 AR10SU/CU MB R2.1 bios
                thanks
                • denizka_s
                  • Jul 2021
                  • Nederland
                  Hallo,
                  Can someone help me with instructions how to recover bios on brick laptop. I also have C70-C with ARES510.FD. Laptop is brick after bad bios update.
                  Best regards
                  • peste
                    • 13920
                    • ROMANIA
                    Originally posted by denizka_s
                    Hallo,
                    Best regards
                    you will need an SPI programmer ... CH341A
                    https://www.youtube.com/watch?v=DWWigscuQDY
                    more details can be found on the internet ..
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
                    • DProf.
                      TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                      by DProf.
                      High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                      Toshiba Dynabook T55/AB, PT55ABP-BJA2
                      MODEL NAME. Satellite L50-D series
                      P[ART NO PS57MN-00600R
                      Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                      09-26-2024, 04:30 AM
