Samsung Laptop BIOS needed NP500P4C-T03CL
  • MCardona81
    • Oct 2016
    • 11
    • Colombia
    hello
    I need the bios for bios file for a Samsung series 5 Laptop
    Samsung NP500P4C-T03CL
    Bios Version: P04RAB or P08RAB
    My bios needs to be cleaned from initialization data and reflashed. So I need to dumped bios with which that comes with ME firmware version.
    Any help is appreciated
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: Samsung Laptop BIOS needed
    Originally posted by MCardona81
    hello
    post your old bios here, maybe someone can help you to clean your ME region..
    check this link:
    https://onedrive.live.com/?authkey=%...&action=locate
    • MCardona81
      • Oct 2016
      • 11
      • Colombia
      check this link:
      thank you for the link. I will post my bios and hope that someone can clear my ME region
      https://1drv.ms/u/s!AhuvrqFPF0hqi0OhqfawitgmZbWu
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        your post file only update file, No descriptor Region and no ME Region.
        Try flashing this file with any SPIprogrammer, backup your bios first, and confirm working or not
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          I worry if the owner post don't have any SPI programmer or dunno how to flash/re-flashing bios
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            whistle:
            we"ll see
            • MCardona81
              • Oct 2016
              • 11
              • Colombia
              whistle:
              we"ll see
              I dont have a SPI programmer
              I am a complete noob about bios flashing / reflashing so be gentle
              • abrariqbal
                • Apr 2018
                • pakistan
                i am having laptop samsung np500p4c-s01ae i want to refresh my bios does any one have bios file for my laptop and how i update can any one explain to me thanks
                • Kelvonga
                  • May 2019
                  • 19
                  • Kenya
                  Why should you request for a bios bin file really if you don't even have a programmer and you don't know nothing about writing a bin file on a bios chip?
                  • obbiiwan
                    • Oct 2022
                    • 12
                    • Chile
                    Re: Samsung Laptop BIOS needed NP500P4C-T03CL
                    hello someone who could send me the P05RAA or P06RAA rom for NP500P4C-T02CL? i tried to flash with the -T03CL versión with SFLASh32.exe with no lucky and my laptop is bricked :S
                    • obbiiwan
                      • Oct 2022
                      • 12
                      • Chile
                      offcourse Any help is appreciated
                      • Mazorca
                        • Jan 2017
                        • 463
                        This is what I got, p07RAA from samsung update.
                          • 20361
                          Post your corrupt backup.The file posted by Mazorca is a 3MB bios update (bios region) ,it can be merged with your backup.Hopefully then it will be working,unless the updater flashed the Micom (EC) firmware as well,if it did it might be ok if it shares the same version as the T03CL.If the laptop boots with the fixed bios you can run the P07RAA update exe from windows to update the Micom FW ,if Mazorca posts the exe.
                          • obbiiwan
                            • Oct 2022
                            • 12
                            • Chile
                            thanks, but i have the same and even when i try to force to flash with no errors (WinFlash.exe /sv /svs /sd P07AA.rom) looks to work, but my laptop keeps in boot looping with empty boot list.
                            I remove Bios bateria por a while and nothing hapend
                            • obbiiwan
                              • Oct 2022
                              • 12
                              • Chile
                              Originally posted by SMDFlea
                              Post your corrupt backup.The file posted by Mazorca is a 3MB bios update (bios region) ,it can be merged with your backup.Hopefully then it will be working,unless the updater flashed the Micom (EC) firmware as well .If it did it might be ok if it shares the same version as the T03CL
                              i take the backup file with sflash32.exe if thats is the correct file, here you are
                              by the way, thanks.
                                • 20361
                                What OS do you have installed.The later bios versions support UEFI, if you have win 7 then an older P05 version would be best,if you can find one
                                • obbiiwan
                                  • Oct 2022
                                  • 12
                                  • Chile
                                  i had pop os, then win 10 installed from usb, but it doesn't run from hdd.
                                  P05 it would be good, but i can't find for internet somthing por T02CL
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    obbiiwan, do you by chance have an intel core i3 11th gen on the laptop? No drives show up but they do on BIOS Settings. Can't install or run, no bootable device?
                                    • obbiiwan
                                      • Oct 2022
                                      • 12
                                      • Chile
                                      No, i have a old samsung laptop with i5 3th gen, but the behaviour is similar to what you tell.
                                      I made the mistake of turn on secure boot in order tu run Pop OS and after that i tried constantly boot and bios died
                                      • Mazorca
                                        • Jan 2017
                                        • 463
                                        We really need your complete BIOS bin. You need a programmer, CH341a is the cheapest. If possible, try not to use the clip, although if you get three or more constant readings, starting from scratch, you are good then.
                                        • Bloodhoundje
                                          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                          by Bloodhoundje
                                          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                          I have desoldered the bios chip (GigaDevice...
                                          03-16-2024, 03:12 PM
                                        • thxd43
                                          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                          by thxd43
                                          Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                          I have a Lenovo ideapad 330S - 14IKB laptop.
                                          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                          02-23-2023, 08:37 PM
                                        • Reda123456
                                          HP ENVY Laptop 16-h1023dx bios needed
                                          by Reda123456
                                          Hello i got this computer, its the HP ENVY Laptop 16-h1023dx the motherboard code is JPR64 LA-M841P Rev 1.0 2022-12-12 and serial number is CND3420BTN so the problem is that this laptop won't boot to a windows or a bootable windows usb installation or anything, ive updated the bios using hp recover bios tool with a usb drice but still same problem, so i am confused, is this a bios problem or what? And if anyone could gimme a working bios bin i'd appreciate it...
                                          02-16-2025, 03:06 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • Loli Popu
                                          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                                          by Loli Popu
                                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                          12-13-2024, 03:28 AM
