Apple Macbook Pro A1278 BIOS Dump
Every donation made will go towards server fees and maintenance costs. -
Re: Apple Macbook Pro A1278 BIOS Dump
Hello, I have a mac a1278 that emits beeps at startup. I tried with uploaded bios on the page but it leaves the screen blank.
the model is A1278 820-2565-a emc: 2555 from the year 2009Attached FilesComment
hi, i have a bios dump of my 2012 macbook pro emc 2554, it has an efi lock i need removed. can anyone help?Attached FilesComment
tryAttached FilesComment
macbook pro a1278 820-2936-a
help with bios firmware there is a password in bios
>Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Please help unlock this oneAttached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
It's not related with the unlock, maybe indeed you're doing something wrong
HereAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Buen día gente, preciso sacar contraseña de macbook a1278 con placa 820-3115-B emc:2554 . muchas gracias desde ya. dejo mi bios por aca
Good morning people, I need to get the password for macbook a1278 with motherboard 820-3115-B emc:2554. Thank you in advance. I leave my bios hereAttached FilesComment
try and reply with results also please speak in EnglishAttached FilesComment
hi
i have dump from MacBook pro A1278 2x locked
please unlock if you are able. thank youComment
mac c2vg5k44drj7.BIN dump is corrupted, read the chip again, use verification!
Second dump is unlocked, here you areAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
post the serial number - https://www.badcaps.net/forum/showthread.php?t=103570
.Comment
Thanks! mac c1mllheedty3 is working perfectly! i have read the second chip again. here it isAttached FilesComment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
