I need this dump 820-3209-A
Macbook air a1466 dump
by yura8Hi there! I have not so usual situation...
I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
P.S. If you have else any ideas about repair, or you had a similar...-
Channel: Schematics and Boardviews
12-20-2024, 02:31 PM -
by psdavid65I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... -
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by dbuergiHi all,
i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
Any ideas where to look?... - Loading...
