Need bios dump for Elitebook 850 G3
  • Markus1741
    • Sep 2020
    • 851
    • N/A
    #121
    Re: Need bios dump for Elitebook 850 G3
    Originally posted by drobino
    Hello guys, i was try unlock my bios on HP 850 g3 with soft hpunlocker unfortinatelly now is laptop dead only light on power botton blink then nothink will happen (0AMP drawing). status led blinking 4times white and amber then stop. I was try original bin but doesn't work either. I was check soldering many times nothing looks bad. Can someone check my original bios? Thank you very much
    Try me clean file from your original backup ...
    Good luck ...
    • drobino
      • Jun 2021
      • 12
      • Czech republic
      #122
      Good luck ...
      Thank you unfortunately doesn´t work. Still the same thing, probably EC firmware goes wrong? I have 3.3V on pin 8 and 1 on bios chip only 1sec after I plug in the charger. No reaction on power botton. Have HP 850 writen EC in bios?
      • drobino
        • Jun 2021
        • 12
        • Czech republic
        #123
        Hi, could someone take another look at my bin files? Laptop completely unresponsive after removing the bios password, zero Amp consumption. on pin 1,2,5 and 6 clk of both chips i can see communication on the oscilloscope for a short time after applying power but that's it. What I tried:
        I cleaned the ME region, Compiled a new clean bios from the HP site, checked several times the soldering around the bios chips,
        I also replaced the EC npce586 itself but no change. If anyone has any ideas I would be very grateful thank you
        • zmezm1995`
          • Nov 2020
          • 94
          • iraq
          #124
          need bios for my laptop hp elitebook 850 g3
          motherboard number 6050a2892401-mb-a01
          cpu i7
          SN# 5CG6464FK9
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            #125
            Please try and report
            • seifaldenn
              • Apr 2019
              • 40
              • Egebt
              #126
              Hi i need fix bin 850g3
              The backlight works without data
              Caps look 1 error lamp
              6050A2892401-MB-A01
              i5-6300U
              • hoaca388
                Badcaps
                • Jan 2022
                • 11878
                #127
                6050A2892401-MB-A01
                i5-6300U
                Serial number ?
                • seifaldenn
                  • Apr 2019
                  • 40
                  • Egebt
                  #128
                  I don't know, his book is not available
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11878
                    #129
                    The serial number is on the bottom of the laptop : 5CG7221438
                    • seifaldenn
                      seifaldenn commented
                      Editing a comment
                      Thank you, it works and the latest version ❤️‍🩹
                    • seifaldenn
                      Editing a comment
                      The device freezes and restarts when entering USB to download a new version
                  • seifaldenn
                    • Apr 2019
                    • 40
                    • Egebt
                    #130
                    With the appearance of a blue screen when entering Windows or Windows Mini USB or Restart, I changed the RAM as well.
                    • seifaldenn
                      Editing a comment
                      I connected to the Internet trying to update the Bios from Bois. It was updated to 1.60 and the same problem
                  • snake35
                    • Jan 2024
                    • 5
                    • France
                    #131
                    Hi, could you please help me unlock my Elitebook 850 G3
                    SN#5CG73613R9
                    Regards​
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11878
                      #132
                      SN#5CG73613R9
                      Regards​
                      Unlocked
                      • snake35
                        • Jan 2024
                        • 5
                        • France
                        #133
                        It works fine, thank you
                        • steamnw1
                          Daniel
                          • Oct 2023
                          #134
                          Hp 850 g3 , lost original bios file can anyone help with a clean bios ? Thanks
                          serial number
                          SN 5CG7060865
                          • munfler
                            • Jul 2024
                            • pakistan
                            #135
                            Hi I need bios for hp 850 g3
                            backlight and capslock blink with no display
                            SN 5cg8334b5s
                          • Hachem25
                            • Aug 2021
                            • 45
                            • algeria
                            #136
                            hello. i have this hp elitebook 850 g3 ,
                            sn: 5CG82809DL
                            mb: 6050A2892401-mb a01
                            when i power it on no display and fan at max, maybe it need me cleaning, i tried different dumps but no result .
                              SMDFlea commented
                              Editing a comment
                              post moved from 840 G3 thread topic to 850 G3
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11878
                            #137
                            sn: 5CG82809DL
                            HP EliteBook 850 G3 Base Model Notebook PC
                            • princeas50
                              • Feb 2021
                              • 25
                              • Ghana
                              #138
                              Help bios password Hp Elitebook 850 G3
                              sn: 5cg63934bk
                              Attached bios
                                • 21145
                                sn: 5cg63934bk
                                Attached bios
                                Read the password guides, try to unlock it yourself using RCUnlocker - https://www.badcaps.net/forum/troubl...rces-and-tools
                                • princeas50
                                  • Feb 2021
                                  • 25
                                  • Ghana
                                  #140
                                  Will RCUnlocker work on Hp Elitebook 850 G3
                                  if yes then i need RCUnlocker. anyone can upload pls.
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • haitham sharabati
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    💀 Problem:😅
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • DynaxSC
                                    by DynaxSC
                                    11-17-2023, 10:56 AM
                                  • mediadoctor
                                    Need bios dump HP EliteBook G845 G8 with AMD and Touchscreen support
                                    by mediadoctor
                                    Can you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
                                    07-20-2025, 09:38 AM
