Need bios dump for Elitebook 850 G3
  • zyze
    • Jul 2020
    • lietuva
    #101
    Re: Need bios dump for Elitebook 850 G3
    hello Maybe someone can help me. I have a hp 850 g3 and I made a mistake while reading the bios file. I did not save the scanned file in the trash. And then I deleted it. Now I try many bin files and none of them work. When I turn on the headset spins loudly and the screen is black.
    how can i restore the bios file? Thank you
    • peste
      • 12959
      • ROMANIA
      #102
      Try a bios from the site, according to the motherboard model.
      • alaaljumaily
        • Jan 2022
        • 19
        • IRAQ
        #103
        Originally posted by peste
        try..
        thanks YOU brother
        • cesaro
          • 28
          • N/A
          #104
          HELLO,
          can you unlock password of this bios hp elitebook 850 G3 please
          thank's
          • hardware1
            • Sep 2021
            • 2940
            • N/A
            #105
            Originally posted by cesaro
            HELLO,
            thank's
            Here's your Unlocked BIOS, if the Password still present you must upload the other Chip (EC Chip).
            all donations are welcome,
            • cesaro
              • 28
              • N/A
              #106
              thank's , it give me black screen with caps light and max fan speed , what you mean by ec chip ? the second bios chip ?
              thank's
              • hardware1
                • Sep 2021
                • 2940
                • N/A
                #107
                thank's
                Yes the second Chip, but before that your device should works fine with the file that I uploaded. Check your soldering connections and give the device 2 minutes to boots up. If the device doesn't work, try to Program back your Original Locked file and see what will happen.
                • cesaro
                  • 28
                  • N/A
                  #108
                  the soldring is ok , voltage ok , i tried the original locked bios , it doing the same thing , black screen and caps light and speening fan
                  i have saved the original bios by ezp2019+
                  first time , before programming i could start laptop
                  • hardware1
                    • Sep 2021
                    • 2940
                    • N/A
                    #109
                    If the device was working before you touch the BIOS Chip, it should works fine after Programming back the Original BIOS. Otherwise you may have moved any components nearby the BIOS Chip, you choose the wrong settings when Programming the Chip or the Chip has burned.
                    • cesaro
                      • 28
                      • N/A
                      #110
                      I checked, there is a resistance of 33 ohom which left its place because of the hot air, I put it back, and everything works fine, so the bios is good, no more password
                      thank you very much, it's a pleasure
                      • hardware1
                        • Sep 2021
                        • 2940
                        • N/A
                        #111
                        Good to know, You're Welcome.
                        • munir100
                          • Dec 2018
                          • 182
                          • uae
                          #112
                          HI every one i have hp elitebook 850 g3 touch not work here is bios
                          • tsm1
                            • Jun 2023
                            • france
                            #113
                            need unlock dump bios for Elitebook 850 G3
                            hello
                            need unlock dump bios for Elitebook 850 G3 i upload the dump.
                            thks
                            • peste
                              • 12959
                              • ROMANIA
                              #114
                              Re: need unlock dump bios for Elitebook 850 G3
                              Originally posted by tsm1
                              hello
                              thks
                              try..
                              • tsm1
                                • Jun 2023
                                • france
                                #115
                                thks but not workin only led green blink
                                • peste
                                  • 12959
                                  • ROMANIA
                                  #116
                                  write the bios again with the password and see if the laptop works.
                                  • tsm1
                                    • Jun 2023
                                    • france
                                    #117
                                    yes it work with original dump
                                    • peste
                                      • 12959
                                      • ROMANIA
                                      #118
                                      try post #114 again.. it should be ok..
                                      • sploxxxaq
                                        • Jun 2023
                                        So i have few questions regarding HP 850 g3, not sure where to go with it but since this thread is about it.. hopefully someone can share their wisdom with me.
                                        1. I wanted to edit some DMI, i started with BCU then NbDmiFit. Unfortunately doesn't work since MPM is locked. I did look up any possible options to unlock MPM and nothing seems to work.
                                        Is it possible to unlock MPM on this model without programmer?
                                        2. Since i failed at that. I went to edit bios. Unfortunately i do not have programmer, so i could only update bios through usb. I read somewhere that changing UUID to FFFF will kinda unlock MPM? But bios update did not keep any changes made regarding UUID or others i changed. Duh.
                                        Is it possible to edit bios to change DMI or unlock MPM while updating it through USB?
                                        Summarizing. Can anything be done without programmer?
                                        BCU gives me access denied error 6, Uefimpmunlock gives Failed Locating Mpm Protocol - Not Found.
                                        • drobino
                                          • Jun 2021
                                          • 12
                                          • Czech republic
                                          #120
                                          Hello guys, i was try unlock my bios on HP 850 g3 with soft hpunlocker unfortinatelly now is laptop dead only light on power botton blink then nothink will happen (0AMP drawing). status led blinking 4times white and amber then stop. I was try original bin but doesn't work either. I was check soldering many times nothing looks bad. Can someone check my original bios? Thank you very much
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • mediadoctor
                                            Need bios dump HP EliteBook G845 G8 with AMD and Touchscreen support
                                            by mediadoctor
                                            Can you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
                                            07-20-2025, 09:38 AM
