hp 240 g4 bios need
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Hp 240 G4 need bios to fix
    @peste thank you your bios is working i just figured out the culprit was bq728 ic
    • kus234
      • Jul 2015
      • 35
      • java
      Re: hp 240 g4 bios need
      test
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
